New User hoping for advice on center channel selection
Hi, I have a pair of Eosone RSF1000 front speakers, and I'm trying to determine what a good match for a center channel speaker would be. Originally, they were matched with an RSC-300, also made by Eosone, but they are difficult to find anymore. I would love to hear from anyone as to a suggestion. I know ideally the front line of speakers should be timbre matched, and from reading some of the posts on this site, I'm sure several of you will have great opinions. I look forward to reading your replies. Thanks in advance, and Happy New Year everyone!!
Welcome to the forum, Len. I don't have any experience with the speakers you mentioned, but hopefully somebody here will be able to share a little knowledge with you.McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
Any of the current Polk centers would be OK, the CSiA6 would be the closest in terms of matching the fronts (1" tweeter, 4" mid, 6.5" woofer).
The CSiA4 would probably be close enough, and not too pricey for what you're looking for.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
I would grab a cs400 or cs400i. Most likely similar tweeters, from a similar era. Cheap on the used market, and sound quality is very good.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
http://www.ebay.com/itm/EOSONE-RSC-300-Center-Speaker-/232191404529?hash=item360fafa9f1:g:rlcAAOSwA3dYZ0aR
May still be available. First one I happened to see. -
Or complete the 5.0 setup here:
http://m.ebay.com/itm/EOSONE-RSC-300-Speakers-/371819529714?_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20150519202348%26meid%3Dac9beab9f1154d02b841c446b5b3ccfb%26pid%3D100408%26rk%3D1%26rkt%3D25%26sd%3D232191404529&_trksid=p2056116.c100408.m2460
But I still might opt for the cs400i, no doubt better sqLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
