Yammie receivers
Willow
Willow Posts: 11,060
edited April 2004 in Electronics
I want to know if anyone has ever used the centre chanel EQ on their yammies ?? I'mnot sure at all how to use it or if I should use it at all any help would be appreciated !!
Post edited by Willow on
  • MSkeezer
    MSkeezer Posts: 1,183
    edited March 2004
    Looks like I'm in the same boat as you. I have no idea what to do with it. lol. I've got the Yammie RX-V1300.....
  • stanman
    stanman Posts: 6
    edited March 2004
    I've made use of the center EQ on my HTR-5650 before. It was somewhat useful when I was using mismatching center and mains a while back. The problem with this feature is that it can take a pretty long time to configure, and there really isn't an easy way to measure the difference/similarity between l/r and center. The manual says to use the test tone, so that's what I did. Essentially, I tried to make the test tone sound the "same" as the l/r mains.
    At the time, I was using a tiny bookshelf speaker that was smaller than the R15s I was using as l/r. Everything was different with that speaker, incl. woofer and tweeter sizes, crossover point, etc. Took a while, and I don't think I ever got it down perfectly. Anyways, since then I've added RTi8's and a CSi3 to the front, and I set the center EQ back to default, since those 3 front speakers are already pretty well matched tonally.
    If anyone has a more scientific way of doing this adjustment, please post it up. I think all us yammie-users could use the help!
  • gacole2000
    gacole2000 Posts: 255
    edited March 2004
    Stanman is correct. It is used to try and balance the tonal qualities of mismatched speakers to create a better pan with the front soundstage. If your speakers are timbre matched this should not be an issue.
    AVR: Yamaha RX-V661
    DVD: Yamaha DV-C6480
    BR: Samsung 1600
    Mains: Polk RT55 (bi-amped)
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
    Projector: Optoma HD70 w/ 106" Elite Screen
    Power: Panamax MAX 5100
    Remote: Harmony One
  • mgaitonde
    mgaitonde Posts: 17
    edited April 2004
    I've used the Central channel graphic Eq. Although the manual does mention matching the center's tone with that of fronts, I'm not adept enough to match them precisely, just by listening to the tones.
    Anyways, the other benefit you could have is: if you think a certain range is lacking in your center channel, you could enhance it. E.g. if you think the baritone (Male voice) is not manly enough or is too chesty, you could play with the 300K and 1K range. Or if the highs aren't chipy enough, play with the 10K. You get the idea!
    This is certainly not scientific and if anyone knows better usage of it, please enlighten!
    I wonder where this figures in the SPL calibration procedure. After the calibration is done, if I change the graphic eq., will it disturb the settings ???
    BTW: I have Yamaha 5660+rm6005+CSi3
  • Willow
    edited April 2004
    yes please help !!!
    I have
    RXV540
    rti4
    csi3
    r10
    psw202 (needs to change)
    marantz DVD
    sony VCR
  • gacole2000
    edited April 2004
    As with everything with this hobby, the main thing is what sounds good to YOUR ears. You want to have a smooth pan across the front soundstage, however, if you tweak your center a little and it sounds good to you, tweak away. However, I might suggest not going to extremes, in the interest of a seamless soundstage. Since, I have a CS400 I do bump up the 100Hz 1 notch, for a little more punch. Have fun and experiment a little.
    Greg:D
    AVR: Yamaha RX-V661
    BR: Samsung 1600
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Remote: Harmony One
