Recommendation for a TT cart on the cheap
Question for you teetee lovers on the forum. I am looking for a cart to just basically throw on a turntable that will get gifted for Christmas. The cheaper the better as it can always be upgraded later
  • Nightfall
    Nightfall Posts: 10,083
    edited December 2016
    afterburnt wrote: »
    Village Idiot of Club Polk
  • polkfarmboy
    polkfarmboy Posts: 5,703
    That's cheap but a little too cheap, maybe something that cost a little more and used would be better.
    txcoastal1 Posts: 13,520
    Careful with used especially with your record...just saying
    Set a budget
  • lightman1
    lightman1 Posts: 10,803
    Mine!
  • hochpt21
    hochpt21 Posts: 5,423
    I've got a Grado Gold I may be interested in parting with. The current stylus has about 300 hours on it, so plenty of life left. I also have a NIB replacement stylus for it.
    PM me if it is something you would seriously be interested in..
  • Nightfall
    afterburnt wrote: »
  • Dawgfish
    Dawgfish Posts: 2,554
    PFB, what table/tonearm are you going to be running this on? I ask because you want to match the mass of the tonearm to the compliance of the cartridge. That would make a huge influence on recommending a cart.
  • Dawgfish
    Clicked on the link and it was a cartridge. Was that what you were intending to show in the link?
    mhardy6647 Posts: 35,562
    EDIT - common sense prevailed ;)
  • Dawgfish
    Lol! Seems so@
  • Dawgfish
    So! That is.
  • polkfarmboy
    The cart I listed was that same gt one and on the Amazon page there is a silver add on and that's what looks like is on it. I am still looking at cheap used ones in the $150 range lol. I feel like Scrooge for not spending more but my Father Christmas tab is insane and I keep spending more every year and it's outa hand now. No one ever gets me Schitt !!
  • motorhead43026
    You can't beat the M97XE that Nightfall mentioned. Spend $50.00 extra if makes you feel better. I run one, it is decent cartridge.
    And the boots you lick will stomp you too.
    gudnoyez Posts: 8,227
    I would take voltz up on that Grado Gold and spare stylus.
  • dromunds
    dromunds Posts: 10,175
    That Denon DL 110 that Nightfall mentioned is real good also.
  • Dawgfish
    Yeah any of the above mentioned carts are really good for the money. The Ortofon 2m red is also in your budget and the 2m Blue is at the upper end of your budget. If you are looking for a warmer sound, the Grado and Shure mentioned above fit the bill. If you want a more neutral sound, the DL-110 and Ortofons lean more towards that way. One thing also to consider about the Ortofons, Grado, and Shure is you can get replacement and upgraded stylus for those carts. The Denon has to be retipped.
    nooshinjohn Posts: 26,177
