impedance
On my yammie I have the option to switch speaker Ohms setting, with the rti4 csI3 r10 should I keep the Ohms setting to 8 or to the lower setting ?? of min 4-6-8 ohms please advise
Unless there is something strange about your Polk's, leave the yamahopper on 8ohms as that is the expected average impedence of those speaks.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
thats what I thought Thanks !!!! I was just curious and didnt want to mess up my new yammie or polks !!!!
Gene Dellasala, of http://www.audioholics.com , "I recommend the Minimum 8 ohms setting even for 4 ohm speakers of moderate efficiency (>89dB SPL). Yamaha includes a 6 ohm setting to satisfy UL as well as easing consumer concerns about driving low impedance loads. These switches step down voltage feed to the power sections which can limit dynamics and overall fidelity. My advice is to keep the switch set to Minimum 8 ohms regardless of the impedance of your speakers and ensure proper ventilation of the Receiver."Go BIG or go home!
