FS - 2 (TWO) Pairs of DCM Timewindows
dee1949
Do your research before YOU buy !!! Goggle the speakers and read reviews.
- BOTH pairs for $450.00
.. Own a piece of audio history. A must try speaker from the Golden Past. Hard to come by. I have owned their little brothers, the QED's , basically a half of a Time Window, for 45 years ( used in HT setup now) and still sound great. I also owned Time Windows 1, 1a and 3's over the years .
- They can handle 200 watts easily and really come alive with 100 watts and above.. Great for all types of MUSIC including LOUD Rock from the 70's.
- All drivers WORK perfectly and sound great.
- Wood tops are Excellent. They just need new foam speaker grilles or use as is - shabby sheik.
If you want to restore to original, you can order enough Foam grille below for less than $20.00 per pair
Order FULL sheet - 72"x48" x 1/4" = $16.99 x 2 for both pairs
http://www.foambymail.com/SFF-/speaker-filter-foam-30-ppi.html
.. Beside being awesome speakers, They also make great pedestals for sculpture.
- Do your research. They sold for $800.00 in early 80's. In today's market would take $1600.00 and up. A classic speaker - way ahead of its time.
Specifications:
Dimensions:36"H x 14 3/4"W x 11 3/4"D
Weight:32 Pounds
Power Requirements:10 Watts Minimum per channel 89 dB/watt at one meter;200 Watts Maximum
Impedance:5 Ohms minimum/6-8 Ohms nominal
Frequency Range:25Hz to 18 kHz
Dispersion:180 degrees horizontal/60 degrees vertical.
Specifications do not tell the whole story,listening does. The Time Windows due to their configuration can be literally tuned to any room. That is due to their shape. This was a brilliantly executed design that has remained faithful all these years.
Review below:
https://forum.audiogon.com/discussions/review-dcm-timewindow-1-speaker
...... Google DCM Time Windows. Highly respected with great review
.... also for the true DCM collecter I can add a pair of DCM "QED'S" for $100.00 with purchase. Just add a DCM cx17 bookshelf for center and rear center .
Specifications:
Weight:32 Pounds
Review below:
FORGOT. !!! Pick UP ONLY in Washington DC !!!
... if you are also interested in Classic speakers ?? I also have below for pick up in Washington DC.
- 3 (THREE) SDA CRS+ speakers
- pair of Pioneer HTM 100's 200 watt - no grilles
These speakers are from friends Retirement sales. Cleaning out the closets!
- also a pair of Snell Type E IV. Near MINT once the foam surrounds are replaced. They are in the process of replacement. -
ALSO
...in terms of components. I have B&K. Sorry NO shipping !!
- B&K pro10mc Sonata - Mint
- B&K AVR 307 Home theater receiver -
Just puttin' in a plug for the timewindows. Very good loudspeakers -- quite amplifier-friendly, too.
PS It'd be a lousy idea to put sculptures on 'em and use 'em to play music
GLWTS, as they say!
Are these the same speakers for sale on A/C ??
Because I am The Pumpkinking
... Yes the same speakers. If you want single pair - $240.00 for pick up !!
... One Pair is SOLD. One Pair still available - $240.00
... The second pair has SOLD !!!
... The Second set is still for SALE !!! - $235.00
Both Pairs SOLD !!!!!
