FS: Definitive Technology BP8060ST Pair
VR3
For your consideration is a pair of Definitive BP8060ST. These speakers are essentially brand new. They were badged as refurbished by Definitive for clearance purposes. The speakers have never had any of their protective coverings removed where it is high gloss black. They have approximately 20 hours on them and then were placed back in the box. The box says home products have a 2 year warranty, which I would assume apply to the drivers and not the electronics. As I am sure you aware, Definitive has products dating back to the 90s that are rocking away!
Looking for $750 Plus shipping or we could arrange pick up/meet within a distance
I also have a set of A80 tops, $200 a pair Shipped
High-performance Bipolar tower speaker: 28 Hz - 22 kHz
Powerful, Forward-Focused Bipolar speaker array for wide and immersive sound dispersion
Integrated 10” powered subwoofer and dual bass radiators
Intelligent Bass Control offers enhanced bass while maintaining overall tonal balance
Dolby Atmos and DTS:X compatible with A90 speaker accessory (sold separately)
Bipolar technology for huge room-filling sound for every listener in the room
Built in 300 watt powered subwoofer delivers massive bass, eliminating the need for a separate subwoofer
Second generation patented BDSS high definition drivers for life-like tonal balance, supurb iteligibility and broad dispersion
Slim enclosure takes up just over 1 sq.ft. of floor space
Dimensions (cabinet only, no stabilizer feet): 44-3/16" H x 5-15/16" W x 13-7/16" D (112.2cm H x 15.1cm W x 34.1cm D)
Dimensions (with stabilizer feet): 44-3/16" H x 11-1/16" W x 13-7/16" D (112.2cm H x 28.1cm W x 34.1cm D)
Driver complement: 3 each 4-1/2" (11.4cm) BDSS midrange drivers, 2 each 1" (25mm) aluminum dome tweeters, 1 each 10" (25cm) active subwoofer driver pressure coupled to 2 each 10" (25cm) low-bass radiators
Frequency response: 20Hz - 30kHz
Sensitivity: 92dB
Nominal Impedance: 8 Ohms
A/V Receiver Crossover Setting: Large, full bandwidth
Internal amplifier power: 300 Watts
Auto On / Off: Signal Sensing
Power Requirements: 110 volts A/C (product not available outside of USA, Canada and Latin America)
Inputs: One pair of 5 way binding posts; One LFE input (optional)
Accessories: Stabilizer feet; carpet spikes, hard floor glides
Product weight: 54 lbs. (49kg)
Sensitivity: 92dB
