Upgrading my rear speakers
I am looking to upgrade my rear speakers in my 5.1 setup. My fronts are the monitor 60s and CS2. My rear speakers are the cheap t15s. I am wondeirng whould would work with my setup. I looked at the monitor 45s but since they don't have a hole to mount them to the wall its kind of tough. I am also looking at the rti a1s and wondering i they will work with my other speakers even though they are a different line. Let me know if they would or if there would be a better choice. Thanks.
Ok now I'm debating on the m45s or the tsi100... help
All they have are used ones and not that great of a price when I can buy new 45bs for cheaper -
Will tsi100 match with my my cs2 and monitor 60s or should I buy the monitor 45bs and if I do get the tsi100 will they do fine directly mounted to the wall or would I need to give them space from the wall?
They won't be timbre matched, but they'll still work. Not very much dialogue coming from them.
I decided to go with the monitor 40s I found on amazon for 125 and bought a mount thathe should work
