Another time I do not understand SRS 2 mid woofers/sound
Would it be right that I hear more bass from the outside 6510 array mid woofers than the inside 6511 stereo mid woofers on the SRS 2 ? I listened thru a paper towel roll at low volume when checking a tweeter and it sounds that way. The way it sounds to me is that the SDA MW are running low frequency and the stereo MW are running full range. Always thought that it was the other way around. Thanks.
  • Schurkey
    Schurkey Posts: 2,122
    edited November 2016
    The stereo midwoofers are full-range below ~2KHz. They're reproducing the main stereo signal attenuated at the crossover point to the tweeters.
    The SDA midwoofers are reverse-phase below 2KHz but at half-volume to create the SDA effect, but also add regular-phase deep bass at around 100Hz. The SDA inductor allows the SDA drivers to reproduce the stereo signal , but only at very low frequencies.
    So, sure, you might get the impression of "more" deep bass from the SDA drivers due to the reduced volume higher-up.
  • VSAT88
    VSAT88 Posts: 1,373
    Schurkey wrote: »
    Hey thanks. I do not understand everything you said but I get enough of it to see that its all OK. Thanks,.
