FS: Sonance In-Wall Cinema LCR (pair) & Cinema Subs (pair)
markmarc
Up for sale is a pair of the very high quality Sonance Cinema LCR in-wall speakers and matching dual in-wall Cinema subs. These were recently pulled from a a family room. The LCR1's are still sold new for $1250 each. The (non-powered) subs went for $350-400 each. They all come with the white facing trim and white metal mesh covers. Due to unique mounting issue, on the back of the LCR's are two 3/8 in thick by 10inch wood shims that were glued to the back. The black panels can still be removed to access the crossover and wiring. Due to the weight, the four pieces will be shipped in two boxes. Payment is by PayPal.
$800 plus shipping, that is just 25% of new cost.
Back story- I did some tutoring for the family that owned them, and they gave these to me in lieu of payment as they upgraded to a Dolby ATMOS system.
Specifications for LCR1:
1” (25mm) silk dome,
ferrofluid-cooled
4” (100mm) carbon fiber/
Rohacell laminated cone with a
rubber surround
two 51⁄4” (133mm) carbon fiber/
Rohacell laminated cones with
rubber surrounds
70hz – 20khz ±3dB
6 ohms nominal; 4 ohms minimum
5 watts minimum;
150 watts maximum
90dB SpL (2.83v/1 meter)
perforated steel
LCR2
SUR1
two 1” (25mm) silk domes, ferrofluid-cooled
two 3” (76mm) carbon fiber/ Rohacell laminated cones with rubber surrounds
two 51⁄4” (133mm) carbon fiber/ Rohacell laminated cones with rubber surrounds
70hz – 20khz ±3dB
6 ohms nominal; 4 ohms minimum 5 watts minimum;
150 watts maximum
90dB SpL (2.83v/1 meter) perforated steel
SUR2
Four 51⁄4” (133mm) carbon fiber/ Rohacell laminated cones with rubber surrounds
70hz – 20khz ±3dB
200 watts maximum
92dB SpL (2.83v/1 meter) perforated steel
87/ ” x 217/ ” x 37/ ”
888 888
87/ ” x 217/ ” x 37/ ” (225mm x 556mm x 98mm) 71⁄2” x 201⁄2”
(191mm x 521mm)
19 lbs (8.6kg) each
(225mm x 886mm x 98mm) 71⁄2” x 331⁄2”
(191mm x 851mm)
29 lbs (13.2kg) each
(191mm x 521mm)
19 lbs (8.6kg) each
ferrofluid-cooled
rubber surround
rubber surrounds
70hz – 20khz ±3dB
5 watts minimum;
150 watts maximum
perforated steel
LCR2
SUR1
70hz – 20khz ±3dB
150 watts maximum
SUR2
70hz – 20khz ±3dB
200 watts maximum
888 888
(191mm x 521mm)
19 lbs (8.6kg) each
(191mm x 851mm)
(191mm x 521mm)
19 lbs (8.6kg) each
Former Staff Member TONEAudio
2 Ch. System
2 Ch. System
I forgot to include the Cinema 260 two channel subwoofer amplifier.
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
SOLD on eBayReview Site_ (((AudioPursuit)))
2 Ch. System
