LSi M704c Rubber Foot Thickness
Hello, I'm looking at the LSi M704 but I have a tight space for it and the height may be an issue. The height is listed as 7-3/4". Can someone tell me if that is with or without the rubber feet and how thick the rubber feet are?
Thanks!
  • I measure 3/16th of a inch on mine.
  • Emlyn
    Emlyn Posts: 4,812
    edited November 2016
    Height is the cabinet measurement. They're not really rubber feet, they are small generic stick on bumpers for preventing scuffs and scratches on the cabinet or furniture. They could be replaced with thinner felt furniture protector pads if height is an issue.
  • gw936
    gw936 Posts: 4
    Thanks for the replies. The height on the specs is listed as 7-3/4" but my cabinet has 7-5/8" clearance. If I remove the bumpers will the LSi M704c fit?
  • ken brydson
    ken brydson Posts: 9,019
    gw936 wrote: »
    Get a hammer, make it fit...
  • rooftop59
    rooftop59 Posts: 8,120
    No, it won't fit. I my experience you need at least an 1/8 inch of clearance for any component to actually fit, 1/4 is better. Plus that speaker won't sound nearly as good stuck in a tight space like that. Why spend all that money for very compromised performance?
    Game Room 5.1.4:
    Bedroom 2.1
    msg Posts: 10,459
    Is your cabinet all shelves?
    The cabinet I use has a facing board on the front just above the top shelf where I have the center. There's more height behind it for the speaker to fit, but I had to remove the shelf first, load the speaker on it, and then slide the shelf back in under the facing board, up into place, and then secure the shelf.
