Does anyone use a Microplex M202 print server?
disneyjoe7
disneyjoe7 Posts: 11,435
I trying to use a Microplex M202plus but can't see this on my network. I'm lost.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
  • nadams
    nadams Posts: 5,877
    edited March 2004
    Have you tried the latest management software?
    I don't know anything about this particular print server, but the netgear PS101s that we use at my job get an IP address from the DHCP server first, then you go into the management software and select which one you want to configure and you can then rename it and give it its own static IP.
    Ludicrous gibs!
  • disneyjoe7
    edited March 2004
    Well I not using the update software yet, do to the fact I don't see it with their SET IP software. I have 2 of these so I think I'm doing something wrong.
    Also these are old out of date not current line of Microplex.
    I have the M202 & M202plus.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • nadams
    nadams Posts: 5,877
    edited March 2004
    Have you tried resetting the print server? Sometimes there's a reset button. You either just hold it in for a while, or hold it in while unplugging. Again, I'm going on my experience with the netgear PS101. Do you know if it's supposed to get an IP addy from the DHCP server? If so, do you have a DHCP server, and do you have access to it? If you do, then you should be able to look at the assigned IPs and tell which one is the print server (they're usually goofy alpha-numeric-random names)
    Ludicrous gibs!
  • disneyjoe7
    edited March 2004
    Which one is the print server?
    I don't know that hubs pre assigned a port may have to go back to the manual thanks.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • nadams
    nadams Posts: 5,877
    edited March 2004
    By print server, I just mean the Microplex M202plus itself. Sorry...
    Ludicrous gibs!
  • disneyjoe7
    edited March 2004
    The print server can have a pre assigned http:://192.168.1.???
    assigned to it?
    I trying to get something like this 00:80:72:00:00:00 but the IP assignment software won't see the print server come back no hits nothing but print server and hub say good link.
    :confused:
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • polktycoon
    polktycoon Posts: 35
    edited March 2004
    Did you try the stuff on this page?
    microplex
  • disneyjoe7
    edited March 2004
    No I haven't. Thanks for the link.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
