Adding Bluetooth to non-Bluetooth devices?
WTS
WTS Posts: 170
Is there a Bluetooth (or other) device to add to headphones or active speakers equipped with a 3.5mm jack, to allow a Bluetooth device to communicate with them wirelessly?
I plan to buy an iPhone 7 soon. As you know, Apple eliminated the 3.5mm phone jack.
I have at least two devices that I'd like to use with the iPhone that use the 3.5mm phone jack: a pair of AR Active Partners speakers, and Grado headphones.
One solution is the Apple Lightning to 3.5mm adapter.
Is there a Bluetooth solution, that's good enough to be worth implementing?
My searches haven't turned up anything useful, but I may not be searching correctly.
  • Google blutooth transmitter, lots of them.
  • soundfreak1
    soundfreak1 Posts: 3,414
    There is a Blackberry "GATEWAY" sold on amazon. Does just what you want for about 60 or so.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • erniejade
    erniejade Posts: 6,321
    Chromecast audio on the powered speakers download BubbleUPnp for the iPhone. You can plug the headset into the chromecast also. Not so portable since it needs power but you can power the chromecast with a battery.
    Theres probably a lot more simple solutions out there.
  • http://www.outlawaudio.com/products/btr100.html This might work. The Outlaw audio forum has a decent Q&A section where you can find info or call Outlaw. $39.00 with free shipping
