AMC CVT 2100A Tube Amplifier
Any one have any experience with or have listened to this amp? Friend has one for sale but he's more than a days drive away....thanks in advance for any input.
    heiney9 Posts: 25,421
    Supposed to be pretty good, if not very good. AMC made some solid gear. An off shoot of some sort of NAD.
    Be ware some of the models don't allow for easy tube rolling as the tubes are soldered in. The stock tubes are very inexpensive.
    With the right knowledge I'm pretty sure you can retro-fit sockets. The later models had sockets.
    Those look soldered in and not easy to get out. Still there might be some info on the 'net about adding sockets.
    Or just get a really good quad of Tung Sol's or SED Winged C and solder them in and forget about it. Not as much difference tube rolling power tubes vs. signal/driver tubes.
    This is a hybrid amp in that the front end is solid state and the back end is tubes.
  • NotaSuv
    NotaSuv Posts: 3,871
    Thanks, have found a bit of info on the net and a lot of positive reviews
    EndersShadow Posts: 17,692
    @ZLTFUL
    I think Ryan HAS one of these and had it modded IIRC...
