Help buy AV Home
Hello
You can orient article are you if settings are correct for room 4x4?
VIDEO 30%
AUDIO 70%
Polk Audio RTI A3 Bookshelf Speakers
Polk Audio CSI A4 or CSIA6 Center Channel Speaker
Polk Audio PSW505 PSW111 oR
In addition I have Samsung 65 "4K UHD Curve
Which receiver buy? I need wifi
thank you very much
  • Ii am guessing your 4x4 room size in in meters which would be 13x13 feet. Do you have an idea of how much you wish to spend?
  • befuddle
    befuddle Posts: 126
    Yamaha seems to have the best consistency for long term reliability, with value pricing and performance. Most brands current mid market models range in the 400-700 range.
    If your looking to purchase new I'd suggest goggling "Best value AV receivers for 2016" or something similar to get a list of various recommended brand's features and reviews.
    Bear in mind that if you want to get a definitely notable improvement in the quality of stereo snd, pick one that has pre outs for the front channels.As av receivers are noted for their lack in performance of 2chn music.This allows you to add a external amp to power the front spks. which also improves surround snd since the av receiver is now left to only power the center and rear spks
    For more detailed info on this try goggling "adding a external amp to a av receiver" or something similar
  • rpf65
    rpf65 Posts: 2,127
    http://www.crutchfield.com/p_642SR7010/Marantz-SR7010.html
    This is probably the best deal going for an AVR at the moment.
  • rooftop59
    rooftop59 Posts: 8,120
    I am also guessing you are overseas? That probably limits your options.
    We need a budget, location, and a few options that you are considering to help us guide you.
    And I agree that marantz is sweet, but in US dollars that's probably what you would pay for all his speakers. Seems like overkill to me...
    Game Room 5.1.4:
    Bedroom 2.1
    Yes friend
    13x13 feet jaja ;)
    I like Marantz 1607 but has 50w :(
    I want something simple, but hold the speaker settings.
    with wifi dlna
    I do not think add surround.
    2 front, 1 center and subwoofer. no more.
    thank you very much
  • rooftop59 wrote: »
    if, very friendly
    I am in Argentina
    All is very hard here, but "Polk Audio" is what you get and I pay.
    I provided an example of the price here
    RTi A3 (Pair) 800 US
    Csia4 550 US
    Polk Audio PSW125 Subwoofer 800 US
    Here suggested Marantz Sr 7010 3900 US (WTF)
    Suggesting, for room 13x13 feet?
    I have wifi receiver to use Spotify
    thanks
  • rooftop59
    Hi friend, welcome to the forum!
    I think that you will be very happy with the Marantz NR1607. I have the NR1403 in my bedroom and I have been very happy with it. The Audyssey is excellent, and the 50 WPC is honest, unlike many receivers. Most mass market receivers will state 100+ WPC, but with 5 channels driven that number often drops BELOW 40 WPC. So that Marantz is plenty, smooth sound, very musical, and I think the internet connectivity if offers (similar to denons I have owned as well). And the Marantz has pre-outs for the main channels, so if you ever want more power you can have it!
    So if you have access to a NR1607 in your price range, I would not hesitate.
    Good luck!
    Game Room 5.1.4:
    Bedroom 2.1
  • Thank you so much
    So with this configuration not have problems
    Polk Audio CSI A4
    Polk Audio PSW125
    Marantz NR1607
    Obviously never going to get to 100wats x channel, but listen well.
    As maximum power is listening to 1607?
    Thank you
  • PSOVLSK
    PSOVLSK Posts: 5,407
    I think that would be a nice little setup.
