No expanded sound on the Polk sad 2.3 left speaker
the right speaker works great. Oh, the mystery of it all..
Some final words,
"If you keep banging your head against the wall,
you're going to have headaches."
Warren
    F1nut Posts: 51,692
    You likely have one or more drivers wired incorrectly. Black or blue are positive. White or green are negative.
  • agfrost
    agfrost Posts: 2,464
    How is your room set up? Are you able to keep some distance between each speaker and the side walls?
    Jay
  • warren
    warren Posts: 756
    This just happened, they sounded great the day before, the next day the issue happened, there is sound from the left speaker but it doesn't expand outward to the left as the right one does, thanks for the comments..
    Some final words,
    Warren
