Problem with Totem rainmakers
Long time no posting, been busy amongst other hobbies, anyway.
Yesterday I discover a horrible distortion coming from one of my totem rainmakers. A closer inspection revealed the surround is broken, a line of about 1 cm long.
The problem is that I can't find a surround replacement. The driver is 5.5 in according to totem specs. I bet my best is to contact Totem for a replacement, but looking for other options just in case. What do you suggest? Would you recommend replacing the driver if I can't find the surround? What driver would be a good fit appart from the OEM driver?
Many thanks.
Many thanks.
I would contact Totem.
I think they have also used several Dynaudio drivers and several have been custom in-house drivers...
