Polk rti12
Hello fellas. Hope everyone is doing good. I recently got the Rti12 for $450 a pair. The speakers are rated 500watts. it's said Polks are power demanding speakers. I bi-amped them with Emotiva UPA 500 80 watts channel and Carver mt-1.5 350watts channel. I fed the treble and midrange with the Emotiva and fed the Woofers with the Carver. Any suggestions as to what I did right or wrong? Or I would have to get an amplifier that can pump 500 watts. Also with my connection, am I feeding it with 430 watts as each amp stated? Thank you
    pitdogg2 Posts: 27,916
    forget bi-amping. what they need is good current. The Emotiva amps can be very bright IMO so using it on the highs would be a no go for me. Parasound and B&K amps tend to be a little warmer and can tame the brightness of some speakers like the RTi12.
  • Joey_V
    Joey_V Posts: 8,606
    dafirst wrote: »
    Well first and foremost, how did you find them to sound?
  • Mike Reeter
    Mike Reeter Posts: 4,315
    dafirst wrote: »
    As a rule Polk Audio speakers are not power demanding, with the exception of the RTi12's/RTi9's, it does take a lot of current as stated above to load those three woofers.
    The 12's tweeters are voiced more for a HT application, they are hot. pitdog2's recommendations are spot on, get an amp that has some balls and is not "Hot" or bright, but a little more on the laid back side.
  • dafirst
    dafirst Posts: 20
    Mike Reeter the sound is amazing but it clips at high volume as compared to when I use the rtia6 as the fronts.
  • dafirst
    dafirst Posts: 20
    edited October 2016
    I am currently using Sony E9000Es processor. Samsung 3d Blu-ray Player, Mac mini for my media center and Alesis Deq 830 digital spectrum equalizer. Someone came to buy a Klipsch subwoofer from me and upon seeing the Polks, he asked for a demo. He was speechless. The sound was full and amazing image. Yes the highs were kinda bright though but with the Svs ultra , it was good. Accidentally, my cousin too showed up and I turned off the Svs sub and they both couldn't believe I turned the sub off. But I will need a recommendation as to which amp to buy. I was thinking of Sunfire but my budget now, I can't afford it till I save towards it. secondly, I had a chance of grabing Lexicon Mc-12 unbalanced but was kinda skeptical. Tony Braxton -Unbreak my heart was on spot, You and your friend Dire Straits, Kenny g Forever in love, This Old porch Lyle Lovett were a delight to listen to
    Take the Emo out of the equation, just use the Carver. Also, pay little attention to those "recommended watts" numbers on the back of speakers. Speakers thrive on current, not watts, which is represented in the "amperes peak to peak" number you'll see in stats on amps. Make sure you put the jumpers back on the speakers when only using the one amp....unless you have bi-wire cables.
    Additionally, a little control with that volume dial will save you from replacing tweeters or burnt crossover parts in the near future. Turning it up enough to clip the amp is not good for the amp or speakers.
  • dafirst
    dafirst Posts: 20
    Thank you Tonyb. I appreciate your advise
  • Curtis_H
    Im running my RTi12's with 125 watts from a Marantz receiver (NON Bi-amped) just with these speakers at first, and my max volume is about 70% +/-, then added a PSW505 12" sub, and then CSI-A6 Center, still max listing vol is around 70% +/- AND they sound great, especially with movies with action scenes, smooth jazz music is also pretty awesome... Love these Polk speakers...
    I am think of bi-amping the mids/highs with another channel on the receiver?
    Looking at getting Polk surround speakers, dont know on which model to get, FXi-A6 or 265-RT's and also was thinking of RTi-9's or 7's for the rear speakers!!
    Marantz SR 7009 Receiver
    Polk RTi12 (Fronts)
    Polk PSW505 (Sub)
    Polk CSi A6 (center)
    edited October 2016
    Curtis_H wrote: »
    Waste of time. You may if fact DECREASE the amount of power going to the speakers that way. You only have one power supply in there and it only has so much to give. Most receivers rated at 125wpc in fact are down to 50wpc with more than 2ch driven.
    Welcome to Club Polk by the way.
  • Curtis_H
    Pitdogg2 - Thanks, I love the way it sounds now, so with your and others on the web, given the same advice, I wont bi-amp my RTi12's.....
    Polk RTi12 (Fronts)
    Polk PSW505 (Sub)
  • jwb0007
    jwb0007 Posts: 62
    Curtis_H wrote: »
    Curtis,
    That is good to read. I have the RTi12s and the RTi6s, along w/ the CSiA6 center, too. Outlaw LFM1-EX sub. Absolutely love them/the combo, too. I initially ran the system with my Yamaha RX-A2030 AVR, and I thought it sounded great. Eventually succumbed to "suggestions" that it would sound even better if I had an amp powering the front 12s. So, I bought a 30-year old Yamaha M-65. I love that too, though, I am not sure of the ACTUAL incremental improvement in audio quality (am not really an "educated" audiophile--just love good sound!).
    So, a friend recently asked me to help him achieve a similar quality of sound in his HT, and you probably know the uncertainty that accompanies advising a friend how to spend a couple of thousand dollars, all on faith. So he ordered a Denon AVR-X4100W receiver, and a pair of RTiA9s and CSiA6 from A4L, AND the PSW505 sub (he did not want to spend the $600 for his sub, as I did). Will be buying my pair of NHT SuperOnes for his surrounds.
    Hopefully with the Audyssey Multi-EQ 32 capability of the Denon, we will be able to create the quality of sound that you and I enjoy with our setups!
    Jim
    St. Louis, MO
    AVRs: Yamaha RX-A2030, Onkyo TX-NR646
    Speakers: BIC FH6-LCR x 3, BIC FH-65B x 2, Polk RTi6 x 2, Infinity Primus P362, Klipsch KSF-C5
    Subs: Polk PSW505 x 2, Polk PSW10, Klipsch Synergy Sub-10
  • dalylaleahthor
    If you have the room and can correctly place the fxia6 get the fxia6.
    Epson 3020 projector. Da Lite screen. Oppo 103. Yamaha CXA5000. B&K 7250ii. HSU VTF2. Def Tech Supercube 4000. Polk Rtia9 CsiA6 FxiA6. Monster hts 2600. Home theater.
    Bedroom consist of NHT model 2 powered by Parasound hca1200ii coming from my computer.
    Stuff laying around. Too much to list but don't want to sell either.
