A few more questions???
GT_03
GT_03 Posts: 37
edited March 2004 in Car Audio & Electronics
Thanks everyone so far for all you quick anser to help solve my probs. I got my MM2124 12" and my C.300.2 amp installed this evening and it pounds outta control. I noticed my headlights dimming alot. Should i get a better battery??? I heard Optima is great. Also what does a CAP do??? And if i get one, which brand and size farad??? thanks alot
Post edited by GT_03 on
  • exalted512
    exalted512 Posts: 10,735
    edited March 2004
    id upgrade the magic 3, see what that does
    -Cody
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    edited March 2004
    Cody...and I'm told I dont elaborate on my posts...lmao- why dont you tell the man what the Magic three are. ???
    Do that...better battery under hood and if still dimming...get a second battery or a HO alternator.
    when you get all that fixed..and you have no more dimming...then add a cap to filter the a/c line to your amp ;)
    Have fun
  • exalted512
    edited March 2004
    lol...thats a good question...
    positive battery -> alternator
    negative battery -> chassis/frame
    engine block -> chassis/frame
    my bad...
    magic 3...
    better battery
    cap
    additional battery
    aftermarket alternator
    thats what i would do in that order
    if it stops after replacing those 3 wires then you dont need to do any of the other stuff and so on
    -Cody
  • TrappedUnder Ice
    edited March 2004
    As the church lady would say>>>> I knew you could cody :)
