Is anyone familiar with CORAL 10TX-70 Full range
ZaPHoN
ZaPHoN Posts: 90
edited September 2016 in Vintage Speakers
Is anyone familiar with CORAL 10TX-70 Full range speakers.
I'm trying to figure out what they would be worth and if I could used them to make a set of omnidirectional speakers.
audio-heritage.jp/CORAL/unit/10tx-70.html
Home Theater & Listening
RECEIVER Yamaha HTR6180
FRONT AMP McIntosh MC2125
THEATER AMP EMOTIVA XPA 7
FRONT Polk SDA 1B
CENTER Polk CsiA4
SURROUND LR KEF Cresta 30
REAR Polk Monitor 5
SUB Tannoy TS 10 Subwoofer
NAS 20 TB Raid 3 QNAP
Office
AMP Luxman L210
SPEAKERS Tannoy
    mhardy6647 Posts: 35,460
    Not a fullrange per se but rather a coaxial -- well, some would say "triax", since they have whizzer cones for the MR as well as the (more or less) coaxially-mounted treble horns.
    Coral made some Lowther-like, true "fullrange" (single voice coil) drivers -- those are held in fairly high repute.
    I don't know this particular driver... but I'd expect good things... and a fairly high price tag for a pair on very good condition.
    Should be high sensitity, and (I suspect) low Qts. "Great for tube amps" :)
    If you spring for 'em, try 'em with a single-ended 2A3 or 300B amplifier -- maybe in a pair of back-loaded horn cabinets or a mass-loaded TQWT.
    ... and keep us posted ;)
    EDIT: I suppose you could mount them vertically and make something like the Hegeman speaker of the 1950s (or like the lower-end Ohm "Walsh" speakers, still made even today) ... but these Corals are gonna be best suited for on-axis use, I would think.
    The dispersion of that tweeter isn't likely to be optimal for omni-use (again, I would think).
  • ZaPHoN
    Thanks so much for the info mhardy6647. What do you think the price range should be. They are listed at $200 but seller is flexible.
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    REAR Polk Monitor 5
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
    I would think that's a reasonable price for a pair assuming all is well with them.
  • Captaur
    Captaur Posts: 1
    I know this a really old thread but thought I'd try anyway.
    I was gifted a pair of these speakers some time ago and finally decided to see if they were any good. Turns out they're not. One doesn't work.
    An ohm meter across the terminals shows an open circuit on the dodgy one, 8 ohms as expected on the other.
    Is there any remedy for this? What would I look for on the speaker? Everything looks identical on both units so I can't see what needs fixing, if anything can be fixed.
    xschop Posts: 5,692
    2 words... Wu Coil
