Good *Budget* DIY speaker kits
codycatalist
codycatalist Posts: 2,661
edited September 2016 in 2 Channel Audio
I've recently been thinking about buying a DIY kit and building some bookshelf speakers. I took a quick peek at Madisound but it seems the price gap is pretty big for anything other than Coaxial single driver speaker kits.
Looking for something more along the lines of tweeter with mid/bass combo that isn't above $200. Preferably with cabinets or if someone can point me in the direction of where I can get pre fabricated cabinet pieces (Don't have power tools so will be doing most by hand).
Thanks!
  • Awesome! Being at work doesn't give me a lot of time to search around. I've heard good things about Dayton Audio though. Might pick it up and switch the vinyl to veneer on the cabs.
  • nbrowser wrote: »
    I might find a way to order it myself and get it up here to Canada eh, but for under $200 bones US it comes with everything, boards, crossover parts, drivers, cabinets, grilles, sealant, foam and chassis wire with connectors, other than getting it shipped in parts it's a complete pair of speakers.
    Yeah it seems like a great deal! Like you said the reviews are pretty good, comparing them to $600-800 speakers.
    txcoastal1 Posts: 13,519
    Look for articles in the Parts Express forums of mods done with the kit designs anlong with http://www.diyaudio.com/forums/
    Lot's of good info
    GL
  • Does anyone have experience with single full range driver DIYs? I'm wondering how they sound compared to a traditional tweeter - midrange set up.
  • txcoastal1 wrote: »
    Lot's of good info
    GL
    Great! I have an alone day at the house when I get off work (other half is going out with the ladies) so I will put some music on the SDAs and read for a couple hours. Thanks @txcoastal1 !
    Following and will read up today. Thanks again!
    mhardy6647 Posts: 35,246
    These are halcyon days for loudspeaker kits! There are almost literally too many to recount, at all price points, different sensitivities and (of course) sonic merit. The latter is pretty much a matter of individual taste, though.
    Madisound and even good old Parts Express are excellent sources of kits lesser and greater.
  • Yeah checked out Madisound this morning but it seemed like the prices went from $50 to $150 to $500 hahaha! Didn't check out parts express beyond the dayton audio link mentioned earlier.
    I have built & designed a fair number of SFRD speakers. They are not everyone's cuppa! If you want high SPLs, look elsewhere. If you want big bass, look elsewhere.
    But...if you are looking for modest SPL with a very coherent sound this may be worth looking into. Many folks listen to SFRDs that are poorly done: cabinets unsuited to the driver; not corrected for baffle step loss; too small a driver for the application, etc.
    Also note that the amp can be critical to the result! I have tried some amps that sounded pretty good on multi-way speakers, but sounded unlistenable on SFRDs. One SS amp produced horrible sibilance with Fostex FE206e drivers. With Fostex F120A drivers, the only SS amp that sounds decent is the Pass Amp Camp Amp; but it is heavenly with almost any tube amp. I don't understand why some combinations have synergy and others are a total fail. It's way more complicated than the damping factor that folks go on about.
    For a first taste of SFRD, I can recommend the Fostex Kanspea kit with the optional FF85wk driver:
    https://www.madisoundspeakerstore.com/2-way-speaker-kits/fostex-p800e-diy-kanspea-3-full-range-speaker-kit-pair/
    I built similar speakers using the FF85k driver (now superseded by the FF85wk). On the low end, they will only reach to about 100 Hz. Most regard them as desk top speakers. But if you high pass them and add a sub, they will fill a typical size room to moderate SPLs. With the FF85k and my favorite amps (Yamaha CR-1000 and Sansui 4000 receivers from the 1970's) they don't seem to need any BSC or EQ. Haven't heard the FF85wk yet, but it is reputed to be even better than the old FF85k.
    Good Luck!
    A day without music is like a day without food.
  • FTGV
    FTGV Posts: 3,650
    Take a look at the kit offerings by Meniscus.Several excellent designs at different price points ,many by well regarded designers like Jeff Bagby. http://meniscusaudio.com/kits-c-133.html
    Good Luck!
    Yeah SPL isn't what I am after just good replication of 100hz and up. I can always add a sub if I want to fill it out. As you stated and I have read it seems single full range drivers work best with tube amps and hardly with SS. I can't quite drop the coin for a tube pre or amplifier so I might stick with traditional tweet/mid combos.
  • Here is another great place to checkout speakers:
    diysoundgroup.com
    They sell kits and you can even have the xover built for a small fee....
