Custom (Goldpoint switches) input/output selector
ALL212
More that has to go...
I had an "issue" in that I wanted to have my digital and analog available to my headphone amp and I had two headphone amps (Bottlehead Crack and S.E.X.). I built this from Goldpoint switches, decent RCA's and silver tinned copper wire. Since I built this I've put in a new headphone amp that has two inputs and sounds better than either of the other headphone amps - now using the Bottlehead Mainline. The top plate is stainless steel. Sound damping on the plate to cut down on the boing as the switches are moved. Machined (Goldpoint) aluminum knobs. RCA's are offset so you can bring in connectors from the sides as well as front or back.
You can pick your base or if you'd like both just add $25 (to mainly cover shipping as I'll have to put it in another box).
This is NOT a preamp nor does it combine inputs to outputs. Select 1 of 3 inputs and direct it to 1 of 3 outputs.
Price is just to recoup the cost of the parts and shipping.
1 box - either color. $225. Add the second box $250
Aaron
Enabler Extraordinaire
Bump... I know this is a bit esoteric but I thought I'd give a whirl here anyway.
Last bump.Aaron
Enabler Extraordinaire -
It isn't esoteric at all -- it's a very elegant little option creator.
