Hi guy's
I am new here and just picked up a pair of SDA-1 speakers and was wondering if anyone uses the Onkyo M-504 to drive them. I can't find any info about the amp be a common ground or not. I went on the Onkyo site and it didn't even say in the manual they have there. Any help would be appreciated. Thanks for any help. Tom.
  • kharp1
    kharp1 Posts: 3,453
    edited September 2016
    I can't speak to your specific question, but, my experience is there are plenty here that can and will
    Did you try the search engine here on the forum?
    Welcome to the forun.
  • Hi kharp1, Yes I did a search but couldn't find the info I was looking for. I will keep looking and should find out soon. Thanks. Tom.
    pitdogg2 Posts: 27,055
    Use a multi-meter and check ohms at the negative binding post. Of course while it is off and nothing hooked up to it. Report back your findings.
  • You can also call Onkyo.
  • Cartop
    Cartop Posts: 7
    I found out that it is a common ground amp. Thanks guy's.
