Denon owners...
Grimster74
Grimster74 Posts: 2,577
edited March 2004 in Electronics
I'm new to Denon products so I'm not sure if this is a normal thing or not. When I power up my 3805 its makes a humming/vibration noise when cut on. It has never done this until recently. Does this sound normal, its almost like its storing power and when its powered up it releases the left over energy and/or sounds like something rattleing in the power supply. Could really use your help asap so I can return it today while they have them in stock if need be
Post edited by Grimster74 on
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2004
    I can't speak for that exact model, but my CTC dims the lights, and finally "snaps" audibly into kick-**** mode when turned on.....and that's just the first power switch :D
  • TroyD
    TroyD Posts: 13,124
    edited March 2004
    Mark, you fail to mention that it will heat small to medium size rooms. I wonder what the btu rating is on that ****.
    Christ, between you and Jesse, there wasn't ONE piece of gear between you that I could have manhandled out the door by myself in the middle of the night and headed south with under the cover of darkness.
    Of course, when I heard the banjoes playing in the middle of the night, I was locking the bedroom door.
    BDT
  • hotwheelman
    hotwheelman Posts: 1,300
    edited March 2004
    Sounds like the transformer in the power supply humming to the tune of 60 cycles per second.
    "Its worked so far but we're not out yet."
    "Hey big man let me hold a dollar"
  • dorokusai
    edited March 2004
    I wouldn't stress about it, I have heard transformer hum at startup in tons of gear. Just run down to the Tweeter, and see what their Denon demo's do...that would be easy enough. If it is different, then tell them while you are present, what is happening.
    Troy - Those banjo's scare me, I need to start bringing my gun when I go to Jesse's house :D
  • I-SIG
    I-SIG Posts: 2,243
    edited March 2004
    Be careful, Mark, -justin- might kick you out!
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • Grimster74
    edited March 2004
    Well, just got off the phone with Tweeters, they are swaping it out with a new one. They said the new one will be in Tuesday. They also checked the display model and said the display model is NOT doing what mine is doing so they are just going to swap it out. Have to love that kinda customer satisifaction.
  • dorokusai
    edited March 2004
    Glad to hear that, without actually hearing it we can only guess. It is not uncommon for a transformer to hum at startup, who knows, perhaps yours was singing :)
    Wes - I meant to say water shooting device, forgive me :D
  • polkatese
    polkatese Posts: 6,767
    edited March 2004
    Grimster,
    My best friend is looking into getting 3805, along with Anthony Gallo's nucleus and Diva. What's your opinion on the receiver? I recommended him this Denon over the Sony 3000ES. I own Denon receivers and amps in the past but not ES amps, and found them to be very nice. So, very familiar with their sonic quality. Based on his budget, I think both receivers are comparable, interested to hear your impressions. Thanks..
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited March 2004
    My 3803 never did that. It just clicks once for on and off, and also when External Inputs are selected or de-selected.
    SVS
  • Grimster74
    edited March 2004
    Just picked up my new 3805. Not only that but the mic I ordered for the 3805 from Crutchfield came in today also. Looks like I know what I'll be doing tonight. Will gladly post my results tomorrow.
    F1nut Posts: 51,938
    edited March 2004
    Troy,
    WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
  • Grimster74
    edited March 2004
    Well, all I have to say about the new AVR-3805 with the optional mic, room setup/room eq feature is holly @#$%. As far as the AVR recording distances from the mic to the speakers goes, dead on accurate. I measures with a tape measure from the center of the mic to the front of the center channel a distance of 16'-7 1/2". The receiver stored a distance of 16'-7", pretty damn close if you ask me.
    As far as the room EQ went, just amazing. Not really sure what everything really means but the SQ is unbeleivable. When I get home tonight I will record all the adjustments it made as far as the graphic eq. and the parametric eq. Can't understand why all manufactures haven't been doing this from day one. I know alot are doing it now but this is just something short of amazing. So, for those of you out there that aren't really sure if you should get the mic for the 3805, in my opinion, worth every penny if you ask me.:D
  • dorokusai
    edited March 2004
    I am getting more excited by the day :D Hey, did you get a DVD-A yet?
  • Grimster74
    edited March 2004
    You know, I was at BB yesterday and it never even crossed my mind to take a look at them. I may have to just go by BB today on my lunch break. Any ideas on which DVD-A I should get, you know, a good demo for this weekend.:D
  • dorokusai
    edited March 2004
    Don't bother, I will pick you up one as a suprise.
  • Grimster74
    edited March 2004
    Yeah, I'm doing a demo Friday night for my bud that works at Tweeter's. He really wants a PB2+ but just wants to make sure he hears one first before he purchases. Have a feeling he may just order one right after he leaves the house.:D
  • dorokusai
    edited March 2004
    I certainly wouldn't bet against that wager :) He may shite himself, as I am hoping I will do when I visit.
  • Grimster74
    edited March 2004
    As long as your outside when it happens.:D
  • faster100
    faster100 Posts: 6,124
    edited March 2004
    cool, when ya think e-bay will start pushing out these 3805's??
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • Grimster74
    edited March 2004
    In my opinion faster, may still be a while before they hit e-bay. Seems Crutchfield, Tweeters and all other Denon dealers are having a hard time keeping them in stock according to all the salesmen I've talked with.
  • faster100
    edited March 2004
    just found a new e-bayer selling one, he claims to have 3 black and 3 silver,, 1 feedback... selling them for 750.00 thats alot of cash to take a chance on though.. So convince me, whats new with the 05, compared to the 03?? :D
    By the way, i like the silver.... for the first time...
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Grimster74
    edited March 2004
    The first 2 things that come to mind, speaker setup/room eq setup with the optional mic and the 3805 is PLIIx. Sure there are more difference/upgrades but I never owned the 3803. Oh, and 3 componenet inputs and a new remote.
  • Grimster74
    edited March 2004
    120 watts compared to 110. Here, maybe this will help some.
    http://www.usa.denon.com/catalog/pdfs/AVR-3805%20Final.pdf
