CS1000P Sub drivers blown?
GSXSRT4
My CS1000P sub drivers (MW7015) seem to be blown. I purchased the center a few months ago. When I turn up the volume on the sub control on the speaker itself they sound horrible like something is broken/loose inside. I pulled them out I didn't see any damage. When pressing in the cones move freely with no sign of any imperfections. Put a voltmeter on and readings came out good. I can only put the volume close to less than half way on the sub volume control and at that point I don't get the noise. Any thoughts? Thanks for the help.
Answers
When you looked at the woofer was you able to inspect the inside on the inner basket ? Ive read here that sometimes those need to be reglued. Just a though..
Check the spider
As soon as I get the opportunity I will check for both possible issues. Thanks.
How did all this pan out......this is a nice centre : )
I had one that stumped me. It turned out to be the volume control potentiometer.
I replaced it with a new pot and the distortion was gone. -
Since the OP has marked this thread as "Answered" what was the problem?
Pretty-lame to mark it answered and then not say what the problem was.
