Crooked Vacuum Tube?
Nightfall
Nightfall Posts: 10,083
Just wondering if this is an issue or not. It's a 12AX7. I'm going to speak in very technical terms here because I'm a tube guru so let me know if I need to dumb it down.
You know how the pins on the bottom have wires on the inside that go to the bottom plate type deal? That lower plate does not go straight across the tube, it's higher on one side than the other. I only looked at it for a few seconds before packing up to come house/dog sit at my friends so it's not in front of me anymore. It could have been that all of the internals were a little crooked. I even think I remember that the pins that stick out the bottom were longer on one side than the other so if you set the pins on a flat surface the glass looked like it was crooked too but I can't really remember those few seconds very vividly.
afterburnt wrote: »
Village Idiot of Club Polk
  • mikeyb128
    mikeyb128 Posts: 2,885
    I have some NOS GE JAN tubes in the shape just like you described. Never a problem with them, worked perfect. I even recently acquired a pair of NOS Bendix red banks with a crooked getter, no issue what so ever with those either.
    2 channel:
    Theater:
    heiney9 Posts: 25,576
    Shouldn't be an issue. It;s not common but it does happen.
    nooshinjohn Posts: 26,061
    I find tubes like that to be a tad bright. :p
  • Nightfall
    Wanted to show you guys a picture now that I'm finally back home. The tube is sitting on a level and flat surface.
    afterburnt wrote: »
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    Looks like the innards are cocked a slight bit and all the pins are slightly bent to one side as well. I'd call it character. B)
    pitdogg2 Posts: 27,549
    last one built on a Friday late afternoon or first thing Monday morning.
  • ALL212
    ALL212 Posts: 1,668
    I wouldn't use it. The electrons are going to slide down on that one side. Your system will sound louder on that side. Send it to me for disposal immediately.
    Aaron
    Enabler Extraordinaire
