NICE Marantz PM 17 60w/ch reference series integrated amp
geppy1
Selling my Marantz PM 17 Reference Series integrated amp. I am only selling because I am going in a different direction. This PM 17 is the DUAL VOLTAGE model which means it can be used on 115 volt or 230 volt with a flick of a switch. The unit is in excellent condition and everything works as it should. Includes power cord, and copy of the manual. I do not have the remote but universals run it. The PM 17 puts out 60 watts per channel into 8 ohms and 100 into 4 ohms and sounds way more powerful and has a tight grip on the speakers cones.. It is built like a tank and weighs 35lbs. It has an excellent MM/MC phono section as well as two tape loops, three line level inputs plus a special one for CD and a preamp out. The little temp gauge is very cool to look at and works . Highly reviewed with lots of great reviews on line. FYI You can use banana terminals. You just put them in the holes vertical. Asking $495 PM for Pictures
Cool stuff!
Bump
BUMP
