Westmassguy's Idea: Employing Damping to Mitigate Comb Filtering and Lobing
13»
  • plastic_avatar
    plastic_avatar Posts: 747
    edited April 2023
    I wonder if some damping in the passive chamber could bring that down a little...
    I know my Monitor 12 were tighter and less boomy when I did my dynamat-like coating of the passive chamber, but I attributed that to taming those cabinet vibrations.
    Curious what The Hive thinks.
    The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
  • Gardenstater
    Gardenstater Posts: 4,990
    Once you start running sinusoidal sweep tones if it still looks bass heavy and still sounds bass heavy, a couple things to play with could be the amount of foam damping behind the other MW and the amount of weight on the passive radiator diaphragm.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,914
    More baffle bracing should fix that, however worn driver suspensions could be the culprit too.
  • Gardenstater
    Just had the thought that you might want to first overhaul/upgrade the caps and resistors and then re-assess the situation because the electrolytic capacitor especially could have drifted value. I have read that the ESR (effective series resistance) of electrolytics can go up appreciably with age.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • joebass3
    joebass3 Posts: 311
    They are original so it makes sense to start there. Thanks!
  • rodman53
    rodman53 Posts: 18
    Well i'll tell you what helps tame the bass of the 10's for me. All i have to do is turn my bass control down to 10 or 11:00 and for my ears that really helps. Just like if i have a pair of speakers that don't have quite enough base i will turn the bass control up a bit. Not a total fix of course but for me it helps. And it cost nothing to try.
  • westmassguy
    westmassguy Posts: 6,849
    skipshot12 wrote: »
    Westmass,
    Has this been tried on the SDA SRS’s?
    There would be no point. SDA's dimensional woofers produce a different signal than the stereo woofers. This modification is for side by side woofers producing the same signal.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • joebass3
    joebass3 Posts: 311
    edited April 2023
    rodman53 wrote: »
    Repositioning the speakers away from the wall and turning the bass control on the Marantz 2270 down to 10:00 made a big difference! I'll likely still rebuild the crossovers and as @xschop suggested I'll experiment with some cabinet bracing, but for now I'm a happy camper!
  • rodman53
    rodman53 Posts: 18
    That's great to hear! I think the monitor 10s are a great speaker, and with some mods here and there they can be even better. I never did post it but I also did Westmassguy's Idea on my 10s. Thank you Westmassguy! Great too hear someone else has done it to their 10s and also got great results.
  • skipshot12
    skipshot12 Posts: 2,171
    skipshot12 wrote: »
    Westmass,
    Thanks for the splanation….
  • joebass3
    joebass3 Posts: 311
    edited April 2023
    Quick update on my 10's. I was so happy with my 7b's that the 10's didn't get much play time. I'm so happy I did this mod! It got me excited about this set of speakers again and motivated to do the other mods to see just how good they could sound. I just finished rebuilding the crossovers, installing Rob's @xschop semi-rings, and doing some serious bracing of the front baffle. Also got them off the floor and onto stands. OMG these bad boys now kick a$$! I can definitely hear (and feel in my chest) the improvement overall but especially bass response. Even though I could hear a difference, I also wanted to know if i could see it so I re-ran the Spectroid app on my phone. Obviously not done with fancy test equipment but it shows a change. Thanks again David @westmassguy!
  • Gardenstater
    edited April 2023
    Would've been interesting to see a sine sweep fore and after but much smoother! And it looks like you got around 10Hz better bass extension. Well done.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • plastic_avatar
    edited April 2023
    Spectroid... [goes to look]
  • Jazzhead
    Jazzhead Posts: 526
    @joebass3 Excellent results! Your experience shows that 10's can shine with the right upgrades. They do need to be off the floor as I recall. My 12's are 13 in. up, away from corners/rear wall and have plenty of bass and slam. So, did you do Rob's @xschop suggestion of bracing at the 10 and 2 PR position? How's the imaging at this point?
  • joebass3
    joebass3 Posts: 311
    edited April 2023
    I decided to brace 4 spots on the PR. I did the 10 and 2 positions that Rob suggested but also installed them at 4 and 8. I installed them so they could be removed if I didn't like the results, but I don't think they'll be coming out!
  • Jazzhead
    Jazzhead Posts: 526
    You ain't messin' round.
  • SIHAB
    SIHAB Posts: 5,895
    edited April 2023
    Might be time to try these mods and get rid of the lobing. :#
    treitz3 Posts: 20,365
    Lobing isn't....
    Awe, never mind.
  • plastic_avatar
    edited April 2023
    [tip of the hat, joebass3]
    I'm determined to do the damping mods in my 12, and your bracing in all of my Polks:
    Well done. Looks great.
    xschop Posts: 5,914
    Good engineering.You've effectively removed all the energy-robbing flex of that baffle.
  • rodman53
    rodman53 Posts: 18
    Nice job. Looks nice and solid.
