Use Receiver AC outlets
PolkThug
PolkThug Posts: 7,532
edited March 2004 in Electronics
Does anybody use these things, or are they a potential SQ problem?
Post edited by PolkThug on
  • ken brydson
    ken brydson Posts: 9,023
    edited March 2004
    I only use mine for a seldom used tape deck
  • Willow
    Willow Posts: 11,257
    edited March 2004
    when I didnt have an auto on sub I used to use one so I didnt have to get up and turn the sub on/off all the time.
  • PolkThug
    edited March 2004
    I originally used them for my CD player, but now I have everything plugged into a monster power center. I figure that if the CD player is plugged into the ac outlet on the receiver, there is a chance that it could introduce "noise".
  • gatemplin
    gatemplin Posts: 1,595
    edited March 2004
    I use it to turn on my BFD before the sub turns on. If anyone else is thinking of using a BFD, you pretty much have to use the receiver outlet or else you will get a loud BANG when the it turns on.
    Graham
  • Jstas
    Jstas Posts: 14,996
    edited March 2004
    I use them for most of my components.
    Then again, I have pre-amps and amps, not recievers so maybe the seperation of signal and amplification has something to do with noise. I have no problems with it at all. The only problem I really encountered was the tuner would not hold a memory on the station presets until I plugged it into the non-switched outlets. Now it does just fine but I have to turn it on and off.
    Expert Moron Extraordinaire
