Should I add a sub???
AsSiMiLaTeD
I feel like I'm getting really good bass from the 150's, can't imagine it being much better, but that's just because maybe I haven't heard it...
Should I look at adding a sub? How much would it add do you think? I'm trying to put it into perspective and determine if it's worth it...
I see that SVS gets a lot of love on here...which one should I consider?
Thanks as always
Thanks as always
My 02 cents worth i would go with a 12 inch sub from polk i think the model is the psw 505 you should check out cruchfield i know it is not much of a discount but it is a good value for 499.99 in regards to the svs i do not have much experience with those so i cannot tell you what you should do.
I had 150's... alot of bass but not a good match for a strong sub, Its just to much bass and not enough midrange. I say 70's, rt55i's if you can find em, rti38's.. and a Pb1-isd SVS, unless you have a large room, then a pb2-isd or similiar... 2 channel rigs would be great with 150's..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
I replaced my Polk PSW450 12" sub with an SVS PB1-ISD and the difference was dramatic. I think faster100's recommendation is good...the RTi70s will give you strong mids and the SVS will produce a ton of low, tight bass.Mains: Polk RT800i
Center: Polk CS400i
Surrounds: Polk RT35i
Sub: SVS PB1-ISD
Receiver: Harman/Kardon AVR 520
