polk psw111
corneliu38
in Electronics
Hi guys... sorry for my English first...I have a subwoofer Polk psw111 and I have a problem...each time when I tried to put the cordonne power it make a popping laud sound ...if i let the cordonne power in place ,the fuse is blowing...what is happening ...and thank you for any advice !!!
Hello,
Welcome to Polk's forum. Is the PSW111 correct for the voltage of where you are using it?
Regards, Ken -
yes I live in Canada no voltage switch...
It's probably the plate amp, had the same problem with one of mine, I replaced the amp and I was back in business.Home Theater
Same model..? If yes whith which model?
o.k seems nobodys are the other opinions...
It would be best to contact Polk's Canadian Manager, Walter Moser, at: 1-817-660-6601 or via email to: Walter.Moser@soundunited.com and explain that you have a PSW111 with a faulty amplifier. He will ask you the date of purchase and where you purchased the subwoofer from and he will need the serial number. He will help you solve the problem.
thank you for info...
