New Platter Mats from KAB
msg
msg Posts: 10,533
edited June 2016 in 2 Channel Audio
The new platter mats Kevin was working on are now available for order on the KAB website.
http://www.kabusa.com/m1200.htm#mat
KAB Poly-Metal Mat
This new mat from KAB consists of a laser cut aluminum disc dampened on both sides with a clear PVC substrate. While this can be used alone, it was designed to be used with the Technics thinner mat (RGS0008) to make up for the missing weight and height of the original thick mat (RGS0010A)
Our new Poly-Metal mat is 1/8" thick, 11.5625" diameter and over 8 oz in weight.
Compare with IsoPlat mat and other exotica.
KAB Poly-Metal Mat & Technics Thin Mat.
This is a package consisting of our new Ply-Metal mat described above and Technics RGS0008 Thin mat. The two mats together are 1/4" thick and weigh over a pound. Completely eliminates all ringing of the main platter and creates an ideal coupling to the record. Some say the Technics rubber compound offers the best interface to the LP.
