Polk Audio TSx 330T 2-Way Floorstanding Tower Speaker vs polk monitor 60 series II 3 way
saikats
saikats Posts: 2
Hello, I am a newbee to this forum. I am deciding between both of them. I wan tot play both for music and movies, but more for movies. Any advice will be appreciated.
Further, is Polk Audio PSW10 10" Powered Subwoofer (PKAAM1055C) a good compliment to them?
I am flexible to add bookshelf speaker to them later on. But to get started, I was thinking which one is better in terms of listening. If I find both of them for the sam eprice, whihc is better?
Sen
  • rpf65
    rpf65 Posts: 2,127
    Toss up between the speaker. Maybe a slight edge to the monitors. Would probably go with whatever was cheaper.
    I don't think I can count how many better subs are out there than the PSW10. I coiod list about 20 other manufacturers that would fit the bill, but lack of information makes it just a list.
    Things like budget, room size, room construction, and furnishings would help.
  • saikats
    saikats Posts: 2
    Thanks rpf65. My budget is around 500 for the 2 towers and sub. My room size is about 18x29. So the choice is between two polk monitor 60 and a sub from infinity/klipsch whihc is on sale for 150+ vs the deal about 330T with a sub that is suboptimal
  • rpf65
    rpf65 Posts: 2,127
    http://m.newegg.com/Product/index?itemnumber=N82E16882290130
    Probably one of the best budget subs out there.
