NEW JBL STUDIO 590 SPEAKERS in DENVER
nhhiep
Only took out of the boxes to inspect/test. Brand new. $1475. Pickup only, no shipping.
http://www.jblsynthesis.com/productdetail/studio_590.html
http://www.jbl.com/loudspeakers/STUDIO+590.html
The JBL Studio 590BK 2-1/2-way Dual 8" Floorstanding Loudspeaker brings professional quality sound to the home experience. The Studio 590BK uses the technology that JBL engineers developed for pro-audio loudspeakers to deliver accurate, powerful sound to your living room.
250W Recommended Amplifier Power
JBL engineers designed the Studio 590BK floorstanding loudspeaker to deliver enhanced, room-filling sound from a separate 250-watt power amplifier, whether you are using the Studio 590BK as a stand-alone unit or as part of a surround-sound system.
Dual 8" (200mm) ribbed PolyPlas woofer cones
Powerful bass affects resonates through your entire body, creating a soundscape that you can feel as well as hear. The JBL Studio 590BK floorstanding loudspeaker delivers accurate low-frequency sounds from a pair of 8" (203.2mm) ribbed PolyPlas woofers. The ribs improve strength while reducing distortion. The result is rich, powerful, articulate bass.
Symmetrical Field Geometry (SFG) magnet assembly
Thanks to a heavy-duty Symmetrical Field Geometry (SFG) magnet assembly, the Studio 590BK floorstanding loudspeaker's pair of low-frequency woofers delivers highly focused bass. The result is pristine, articulate sound.
1" (25mm) high-frequency compression driver
The JBL Studio 590BK floorstanding loudspeaker's high-frequency compression driver lowers distortion and provides a wider dynamic range than is possible from conventional high-frequency and midrange drivers. The tweeter comprises a one-piece Teonex diaphragm/surround assembly fitted with a 1" (25mm) voice coil that can deliver enhanced vocal articulation.
Glass-filled ABS Bi-Radial high-frequency horn
Horn-shaped loudspeaker designs optimize high-frequency output by directing the sound to the listener with pinpoint accuracy, thereby eliminating reverberation, reflections off walls and other artifacts. The Studio 590BK floorstanding loudspeaker features a glass-filled ABS Bi-Radial high-frequency horn that delivers professional-level sound to your home.
CLow-loss, two-way crossover network
The Studio 590BK floorstanding loudspeaker's low-loss, 2-1/2-way crossover network ensures a clean transition for sound coming from individual low-frequency and high-frequency drivers, thereby reducing distortion while improving clarity.
Bi-wire capability
The Studio 590BK floorstanding loudspeaker will work with multiple power amplifiers or connection setups or both for single-wire or bi-wire operation. The result is enhanced versatility in the ways you can use the Studio 590BK speaker.
Sturdy 3/4" (19mm) MDF enclosure
The Studio 590BK floorstanding loudspeaker's cabinet is built with the same attention to perfection as every other component. Rigid, heavily braced materials prevent unwanted resonances, while non-parallel surfaces eliminate sound interference.
Exclusive design
The JBL Studio 590BK creates a powerful, sophisticated look that will fit within even the most discerning householder's decor.
Bi-wire capability
Exclusive design
new price $1400
new price $1250
