Polk RTi A7 + Integrated Amplifier wpc
Hi,
I'm new at this and am in search of my first polk, I like the RTi A7. I did not want to spend more than € 400 in a amplifier ... my doubt is whether a stereo integrated amplifier, such as yamaha S501 (85wpc) is sufficient. Or would it be better, a rti A3 + sub for this amplifier and My room is 4 x 3 meters. I intend to use only to listen to music.
thank you
thank you
Pretty small room for the A7's, if my conversion is correct. Either the A3's or A5's with a sub would be my choice.
You may also want to look at the LSI M703's. I would lean towards them if music is your concern. -
I agree, for music the 703's are the better choice. That Yamaha would work, but the S701 or 801 would be even better.
