Polk SDA 1.2's Project in Wisconsin
dekuda
dekuda Posts: 756
edited June 2016 in For Sale (FS) Classifieds
Boy, this is tempting for $450.00 on Wisconsin Craigslist... I hope someone here gets these babies.
http://milwaukee.craigslist.org/ele/5623391456.html
HT System
Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
Post edited by dekuda on
  • dekuda
    dekuda Posts: 756
    FYI, I have no affiliation with this seller.
    HT System
  • michaeljhsda2
    michaeljhsda2 Posts: 2,206
    They are 1.2's, not original SRS! Lowest price I have ever seen. For a few hundred bucks they can be converted to 1.2TL's!
    SDA SRS 2.3TL's
    SDA 2B TL's
  • tlarwa
    tlarwa Posts: 30
    I work near the seller, Larry, and have bought several audio components and a pair of Heresy's from him in the past. He's a good seller and very experienced with vintage audio. I wouldn't hesitate to buy from him.
    heiney9 Posts: 25,510
    Check closely as he is recommending all speakers get new surrounds. They are rubber so they can't be "re-foamed", if the driver surrounds have tears, most likely need to be replaced. That can get expensive very fast if you have to replace them all.
  • michaeljhsda2
    edited June 2016
    Seems very strange that every single driver needs new surrounds. What a shame. I can definitely see a large hole in the upper left midwoofer and the 2nd one down from that. Rusty screws not a good sign. Crossover plates are 1.2/1.2TL's which is nice. Interesting that the passive radiators are ok...possibly.
    SDA SRS 2.3TL's
    SDA 2B TL's
    pitdogg2 Posts: 27,333
    Makes one definitely wonder IF the PASSIVES are truly OK. Rusty screws I wouldn't worry about funny thing most Polk Speakers I have ever seen or had has had rusty screws. They seem to rust just from humidity in the air like mine have done here in the midwest humid summers.
  • Dabutcher
    Dabutcher Posts: 2,606
    Just a FYI. I have replaced rubber surrounds that got hard and tore when bigger amp power hit them. Just need to shim the coils and remove dust caps. Just like foam surrounds. Maybe someone can talk him way down and get all new drivers from Polk? Peace. D
  • Gunga
    Gunga Posts: 2
    Can you order replacement midranges directly from Polk like you can the tweeters? Or do you have to try to hunt them down online?
  • michaeljhsda2
    edited June 2016
    Yes, order directly from Polk. Fleebay if you want vintage. Both sound the same IMHO, others disagree.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Dabutcher
    Say you are a forum member and get discount with free shipping. I replaced all eight of my tweeters for $400 and sold the old eight for $250 on eBay.
