Anyone have the Denon 2802?
AsSiMiLaTeD
Does anyone have this and use the pre outs??? Does anyone know if you can get a signal from the preamp outputs and power from the receiver amd on those same channel simultaneously???
The guy I'm looking for is in my same situation, needing more power for his 150s...so he'll need to bi-amp with the receiver and a second amp...
Thanks in advance for any input...
Post edited by AsSiMiLaTeD on
when you hook up to the pre-outputs, the receiver does not shut off the signal to the internal amps.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Exactly what I was looking for...Thanks! -
I can second that, i used my 2802 and a separate amp at the same time,had the 2802 powering the highs,and the separate amp for the lows,worked great.*HT PRE-PRO*:Rotel rsp-1068, *AMP*:Rotel RMB 1095 *DVD PLAYER*:Denon 2200,*CD PLAYERS*,Arcam Alpha Mcd 6 disk carasel,Hughes Hdtv receiver, Hughes hdvr2,*MAINS*:Polk LSI 15'S, *CENTER*:Polk LSIC, *SIDE SURROUNDS*:Polk LSIFX,*REAR SURROUND*:Polk LSI 7'S,*SUB*:SVS PB2+*.MONITOR*:Mitsubishi ws48413 hdtv,Monsterpower hts2500X2,,Sony playstation2,Harmony sst-659 remote
I can third that on using both reciever amps and pre outs. But I had the opposite experience then racer4551. When I used the denon to power the highs and carver for lows, I got very terrible sound.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
I'm looking at the 2802 and 3801 in the Denon line.
I'm looking to get either for around $400, both are in great shape.
Which one would you guys reccomend? I'm leaning towards the 3801 based on specs and features, can anyone give me a reason to go with the 2802 or re-affirm my 3801 decision?
Appreciate it...
