amp's
goingganzo
goingganzo Posts: 2,793
edited February 28 in Clubhouse Archives
any one have B&K amps and is going from 100wpc to 200wpc going to give me a good performance boost
i have
800i manis
400i center
fx 500i rear and rear suround
i have a onkyo 787 and a old 100wpc sony stero recever driveing my rear suround
Post edited by RyanC_Masimo on
  • sgtgto
    sgtgto Posts: 310
    edited January 2002
    Hi:
    I have a B&K 200W X 3 and I am really impressed with it. The extra wattage will give you more head room, and better overall response.
    Remember, you can never have too much power.
    Gary
  • juice21
    juice21 Posts: 1,866
    edited January 2002
    yes, any doubling in wattage will give you a good performance boost. as any audible difference in sound requires a doubling of power, when upgrading an amp, you should always try to double your power. a 30-50W difference will not yeild a great difference(unless you are talking about different maufacturers)...
  • gmg
    gmg Posts: 22
    edited January 2002
    I had a 787 and hooked up a B & K Ref. 7250 to my 2000's. The bottom came alive, to the point of being boomy. But that's another problem. I ended up selling the the 787 and getting the Ref 30 pre-amp. That put a whole new perspective on my music and HT. I'm very happy with the B & K although if I was going to buy it again I would have bought the 6 channel amp for 6.1. Now I have to buy another amp. Will get a 2 channel and go to 7.1. Gordo
