Input on SDA 2B upgrade
Gerres26
Gerres26 Posts: 874
Hi there, so i just picked up a pair of nice 2Bs off of my local Craigslist. I'm loving the way they sound but as always I want to replace the caps to bring them up to par. I have a dilemma though. I dont want to spend a ton of money right now so here are my two options and I want your opinions.
I have a pair of Rdo 194 tweeters my monitor 7s I could swap to the 2bs and then upgrade the caps with more expensive ones like Sonicap since id be saving tweeter money.
Or should I perform the TL upgrade with the 198 tweets but then use cheaper caps, something like Dayton since I have to buy new tweeters this route.
What do you guys think??
  • MrBuhl
    MrBuhl Posts: 2,419
    Just IMO, but Id enjoy them as is for a while, and use that time to save a few more $$ so you can do both.
    The TL mod is certainly worth the small additional effort and cost, this way you'll be able to appreciate what the improvements have accomplished. You also may save yourself by finding a sale on Caps while you're waiting.
    FWIW I think you can certainly do a blend on the caps, Sonicaps high and Dayton's low, that will save you some money on the upgrade, and the high end is where the caps are most critical.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • Gerres26
    Gerres26 Posts: 874
    It seems Sonicap is the preferred replacement cap around here. Am i correct in assuming that or is there other brands I should look into for equal or lesser money that sound very comparable?
  • MrBuhl
    MrBuhl Posts: 2,419
    Yes I think you're right, generally most folks on CP seem to prefer the Sonicaps of late.
    I used Clarity in mine and I'm very pleased with the results. The Clarity's I used, (there are two lines, PX and ESA) were the higher priced ESA - but on sale I still found them for less than the Sonicaps.
    The Clarity PX are a more reasonably priced option generally.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • motorhead43026
    motorhead43026 Posts: 4,140
    edited May 2016
    Sonicaps or Clarity ESA, let your checkbook decide.
    Religion began when the first scoundrel met the first fool……….Voltaire.
