Universal player
Looking for something a little on the warmer side. I just sold my Oppo and I didn't think I'd miss it for blu ray concerts. I was dead wrong. I'd like to stay under four bills but will go higher for the right deal.
  • daboyz
    daboyz Posts: 5,207
    Thanks, Rick. Under consideration. It has Burr Brown 1781 chip set which should be good. I've been leaning towards a Marantz UD5007.
  • skrol
    skrol Posts: 3,472
    I have both the Denon BDP-1611UD and the Marantz UD5005 and the internals are identical as is performance. I am using the Marantz but the Denon is available.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • daboyz
    daboyz Posts: 5,207
    The Denon only does SACD as multichannel, correct?
    pitdogg2 Posts: 27,440
    Shouldn't all mine let you pick. Then disclaimer is I have not had that model
  • skrol
    skrol Posts: 3,472
    daboyz wrote: »
    You can select SACD, Multi or CD layer on the Denon. At least on some (my DVD-2910) you have to select before you start playing.
    Stan
    Main 2ch:
    HT:
    Other stuff:
