NICE Yamaha A-S 700 90w/ch integrated amp w phono
geppy1
Selling my Yamaha A-S700 integrated amp in black. The amp is in excellent condition and works perfectly. It is rated at 90 w/ch and puts out a lot more. Australian Hi Fi measured around 120 into 8 ohms and almost 200 into in to 4 ohms and that is not even peak. The amp section can drive any load and is very powerful. Nice MM phono section also. Many good reviews online. More details below. It comes with power cord and copy of the manual. I do not have the remote but universals do run it and one can find the original on sites for cheap. Yamaha has really made a nice line of integrateds. Asking $295. PM for pictures Thanks
Yamaha A-S700 integrated amplifier
The Yamaha A-S700 Integrated amplifier has inherited the Natural Sound concept of the Yamaha A-S2000 and the A-S1000 Series: By pursuing the reality of musical instruments and the human voice without adding extra seasoning to the music, convey the thoughts of the musician or recording engineer. Expressing the reality of musical instruments is the foundation of Natural Sound that only a musical instrument manufacturer can achieve.
The Yamaha A-S700 Integrated amplifier was tuned with three objectives: to naturally produce the harmonic constituents of violins and other high frequency instruments, to express the rich texture of the human voice and guitars and other midrange instruments, and to prevent the bass of kick drums or orchestra from losing its deep feeling and weightiness. By achieving these three objectives, which is by focusing on faithfully reproducing musical expressiveness, the Yamaha A-S700 fully conveys not only the clarity, but also the joy of music.
The Yamaha A-S700 Integrated amplifier features Yamaha's ToP-ART (Total Purity Audio Reproduction Technology). When processing and transmission of the audio signal is simple and direct there is less chance of it being affected by noise and distortion. Yamaha's amplifier design technology called ToP-ART features I/O (input to output) Direct Symmetrical Design, with left and right channels organized in a straight, symmetrical layout for highest signal purity. Advanced Yamaha audio technology and component parts give the Yamaha A-S700 the winning edge in audio performance. For signal purity, Yamaha's I/O (input to output) direct symmetrical design organizes the left and right channel circuitry in a symmetrical layout. Custom-made power transformer, custom-made block capacitors, two direct signal path speaker relays, one-point grounding system, aluminium-extruded heat sinks and other top-quality parts effortlessly handle demanding audio signal conditions. High-rigidity support and vibration damping are provided by a solid centre bar and Yamaha's ART (Anti-Resonance and Tough) Base bottom chassis.
The Yamaha AS700 features a 'Pure Direct' switch, when this switch is engaged; the signal bypasses the tone, loudness, balance controls, and other circuit, being fed directly to the discrete power amplifier. It travels in a straight line from the volume control; through the high-gain short, direct path is maximum signal purity. The Yamaha A-S700 Integrated amplifier uses high-grade gold-plated input terminals that provide a secure connection and ensure high quality signal transmission.
Specifications
•ToP-ART (Total Purity Audio Reproduction Technology)
•I/O (input to output) Direct Symmetrical Design with top-quality parts, ART (Anti-Resonance and Tough) Base and solid centre bar
•Pure Direct
•CD Direct Amplification
•High dynamic power, low-impedance drive capability
•Aluminium front panel and knobs
•Continuously Variable Loudness Control
•Rotary-encoder input selector with LED
•Remote controllable motor-driven volume control
•Gold-plated input terminals
•Rec out Selector
•Speaker A, B, A+B selection
•Dimensions (HxWxD) in mm 151x435x382
Specifications
•Pure Direct
•Rec out Selector
is this sold?Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
This model of amp did have very good reviews , hope it goes to a good family. GLWTS!
It has been sold.
Congrats on the sale, that was a great deal on it.
