Keeping It Cool-Heat Dissipation
I'm curious if anyone has done anything similar, or in any other pertinent discussion.
I recently put into action a Luxman M-02. I did read that it ran a little hot, unlike the M-2000 I'd been using. The M-2000 has heat sinks on the back of the unit, but the M-02 has top ventilation only. I definitely found that mine did run hot, and I set about finding a way to raise my CX-100 preamp up a bit to improve ventilation and also allow me to place 1 or 2 computer fans on top of the amp. I had a vision of a small metal rack of some sort and, with the help of my lovely wife, found exactly what I had in mind in the housewares section of a thrift store. It was likely some sort of hot dish carrier originally. It does the trick quite nicely and is somewhat discreet in appearance as well. I can also reach in to check temperature, situate fans, etc. Typically I'll run one fan when I'm doing any extended listening; 2 if I'm cranking it. This creates a space of just under 3 inches. Most importantly, the Luxman runs cool as cucumber.
One mod I may make is to add some textured tape to the top and bottom of the rack to prevent sliding when turning the preamp on and off.96if97eowqyb.jpg
Power Amps: Luxman M-02, Luxman M-2000, Luxman M-300
Preamps: Luxman CX-100, Luxman C-1010, Luxman C-120A
Speakers: Polk Audio SDA-2B's (no mods...yet), Klipsch KG4's (Crites Crossovers and Titanium Tweeters), Genesis 1's
Digital Front End: Marantz CD6005, Denon DVD-2200, Fiio X5 II
Headphones: Sennheiser RS180, Sennheiser HDR170 w/Fiio E12 Montblanc (home). Sennheiser HD449 w/Fiio E12 Montblanc (portable)
EQ: SAE 180 Parametric
    EndersShadow Posts: 17,719
    Looks good! Another suggestions is to buy a laptop cooler and do the same. The laptop coolers also tend to use much larger fans turning a lot slower so you can't hear them at all
  • Thanks, Enders. I bought both of these fans at garage sales, and #2 is quite noisy. It needs to go!
    pitdogg2 Posts: 27,245
    Just make sure your pulling air out not in. IME it helps keep dust/dirt out and off the internals.
  • steveinaz
    steveinaz Posts: 19,546
    Search "Cool Components" for a more elegant solution; that Luxman gear deserves it.
  • Looks good! Another suggestions is to buy a laptop cooler and do the same. The laptop coolers also tend to use much larger fans turning a lot slower so you can't hear them at all
    I did pick up a laptop fan. It also has an on/off switch, so that's an improvement.
