Advice Please!
15 years ago, installed new entertainment system (65" Mitsubishi TV, Yamaha receiver, Polk audio 2300 speakers, surround sound). The TV has now died. Bought 65" LG 65UF6450 TV. Was told I need to replace Yamaha receiver to get most from TV (connections need to be HDMI). Don't want to spend fortune on receiver. Best Buy guy told me to be sure to have 100 watts per channel and that it be 8 OHMS. Any suggestions as to what to buy that will work well with the speakers system I have built in?? Not an audio person so need help.
  • Willow
    Willow Posts: 11,228
    Well you don't need hdmi. You can still get Dolby digital and dts through toslink or dig coax. If you want the newest audio formats then you will need hdmi.
  • codycatalist
    codycatalist Posts: 2,662
    Agreed you can use optical audio out if you have it as well. I've heard it isn't the best route but it is the only thing I can do being as my TV doesn't have component out for audio.
    tonyb Posts: 33,069
    You need HDMI with that 4k tv you bought, don't even think otherwise. I'm not familiar with those speakers though. Are they smallish ?
    All receivers today will be 8 ohms capable, thing is if you have hard to drive speakers you may need a 4 ohm capable one. I'm guessing you don't though, so most any receiver from Marantz, Yamaha Avantage line or Pioneer SC line would do you nicely. You can even look for some used and save a boat load of coin.
    If you go too cheap on the receiver, your sound quality will suffer. Midline Marantz, or Pioneer is your best bet for not a lot of coin. Yamaha's in my opinion don't start sounding good until you hit the Avantage line of receivers. Cost is relative though. Whats your idea of not a lot of money ?
  • codycatalist
    tonyb wrote: »
    Why is that Tony?
    tonyb Posts: 33,069
    tonyb wrote: »
    Why is that Tony?
    Because to get the HD pic and possibly 4k content, limited as it is, you need the HDMI. You'll also need the HDMI connections for blu-ray players, gamers if you are one, or any other outboard device. You also won't get the newer surround codecs without it....unless you enjoy buying additional cables and finding a player that has analog outputs which limits you to an OPPO.
    Without the hdmi, you'd be asking for headaches with compatibility issues. The newer 4k TV's, some don't even have digital coax or toslink outputs/inputs. Just a whole host of problems await trying to integrate a non hdmi receiver with a 4k tv.
  • codycatalist
    edited April 2016
    I guess I got lucky then, my 55inch Curved UHD 4k Samsung has optical audio outs so I just run Ps4 HDMI> Tv then Tv Optical audio out > Yamaha HTR-5590. Haven't had an issue, i've heard optical audio doesn't sound the best but I have no gripes so far...at least until I want to upgrade...then I will find something to gripe about.
  • Gunther16
    Gunther16 Posts: 243
    Benefits to using Digital or optical connections to Receiver/Processor. You do not need to turn on your equipment when you don't want to hear sounds thru your HT/Stereo system. Your TV will provide sound. I personally like having the option. The best of both worlds so to speak. Yes it may be a slight (really slight) inconvenience but for me its worth it. Who watches the news thru their Audio equipment anyway. All my video/audio sourcesare going to the TV via HDMI and to my Processor via optical/digital connections. I can have my choice of audio. So ok I have to mute the TV when using the Audio equipment but so what?
    tonyb Posts: 33,069
    The higher end TV's will have those in/outputs. The TV in question has a digital input, but no output. This all varies from brand to brand, series to series, so something to keep in mind when shopping for a new TV.
    Some will have an optical out and not even do 5.1 thru them, pretty silly in my view given todays tech.
    Point is, if you bought a 4k TV with the latest tech in it, why try and pair it up with gear of lessor tech ? Something won't talk to each other along the way and create issues. Even within the different variety of HDMI iterations, there is still compatibility issues. Sure, some of these issues you might be able to do a work around, but why beg for the headaches is all I'm sayin'.
  • honestaquarian
    honestaquarian Posts: 3,260
    Yeah what he said^
    Also you must remember the equipment that is capable of passing the full hundred plus gigabit per second HDMI 2.0 has not yet been released (*even though the manufacturer's are labeling the current crop of audio gear HDMI 2.0 compliant*)
  • trj
    trj Posts: 320
    Completely agree with @tonyb
    HDMI is the way to go. I am still kicking myself for having an SACD player that has analog outs. 6 cables where one cable could have done everything. Need to find one that does SACD via HDMI.
    I am one of those who watches news on 5.1 system. I cant stand the sound from TV speakers. I dont know if my 3 year old TV speakers even work. Everything goes through my receiver and one universal remote controls everything.
    Summing it up, I dont like clutter. Be it wires, cables or remotes.
    If you want to use TV speakers and not the HT, most of the modern receivers have pass through function anyway.
    Now, the receiver recommendation from bestbuy guy would not something I would be taking seriously.
    Do a little research to see what kind of setup you are looking at. If the speakers you have tiny little cubes or bigger bookshelf/towers. Buy a receiver accordingly.
    Sony BDP-S6500 | Raspberry Pi 2 | XBOX One S | Wii --> Yamaha RX-V667 --> Adcom 5006 bridged to 175 watts for front LCR -- >Front: Polk Audio RTi8s | Center: CSi5 | Side Surrounds: RTi4s | Rear surrounds: FXiA4s | Cheap 12" sub woofer|Samsung UN60KU6300
  • honestaquarian
    @trj
    I saw your post on the 4k thread. Take a close look at my last post above.
  • befuddle
    befuddle Posts: 126
    edited April 2016
    I thought it strange that a major brand of that size wouldn't be designed for use with a home theater,
    It could be in error,always best to double check! But looking up the specs list from Best buy shows a lg 65UF6450 to have a optical digital output jack in the rear.
    Using this connection to go to the receiver you can get regular Dob.dig. if the tv and station support it.
    If you have a cable box you can you can use the box menu to assign its dig.coax or optical out to pass the sound to the receiver,
    This way the hdmi connection from the box to tv will allow HD pict and tv snd and surround thru the box dig output to the amp.
    To get the improved DD plus or Dts equivalent a receiver with them would be required which will have the needed hdmi connection for them
    Post edited by befuddle on
    tonyb Posts: 33,069
    trj wrote: »
    Well, not so fast.....the benefit of a good SACD player is also the better build quality and the better internal dacs. Using HDMI would bypass that benefit, which is why you don't see too many with that option.
  • K_M
    K_M Posts: 1,632
    edited April 2016
    befuddle wrote: »
    Most TV's and receivers, have ARC (audio return channel) support and send audio both direction thru HDMI.
    http://www.hdmi.org/manufacturer/hdmi_1_4/arc.aspx
    My one home theatre, everything goes into AVR with HDMI, and receiver out goes to TV thru HDMI.
    The audio from the TV returns back thru the same HDMI.
  • codycatalist
    My Yamaha has DTS as long as my TV can output that format (which it does) through optical. Would HDMI improve that effect?
  • trj
    trj Posts: 320
    @trj
    Hence, I said there, may be "by the end of the year". I am still waiting on the formats to get standardized before buying a new receiver. So hard to wait, I was almost going for yamaha aventage 2050, but :wink:
    tonyb wrote: »
    That is a good point Tony. I was just giving OP options on reducing cable clutter.
    In my case, both may have same DAC. My SACD player is little older than my receiver. Both yamahas. Hence, my advice to OP to search for a receiver that meets his needs/possible upgrade plans and not to listen to the sales guy at best buy. Who knows what other equipments OP will be connecting to his receiver :neutral:
    tonyb Posts: 33,069
    lol.....sales guy at BestBuy is the last dude you want to listen to.
    tonyb Posts: 33,069
    K_M wrote: »
    befuddle wrote: »
    Providing the receiver is ARC compliant too, which isn't always the case when trying to mix and match old/newer technology creating headaches.
    You can use the TV itself to switch inputs instead of the receiver as a work around, but, depending on what you want to accomplish many TV's only have one or 2 HDMI inputs capable of 4k resolutions. The others are not, something else to be aware of.
    If your going to wait to buy a receiver until the formats settle down, good luck with that. They constantly change....to get you constantly buying new gear. You think they want you holding on to that receiver for 10 years ?
  • befuddle
    befuddle Posts: 126
    Mitch- If your still considering if you need a new receiver to go with the tv and issues that concern 4k google-[ Cnet Do I need a new AV receiver to go with my 4kTV] it was a article from last year that helped to clarify things for me from a layman's perspective.
  • footwedge
    footwedge Posts: 475
    tonyb wrote: »
    K_M wrote: »
    befuddle wrote: »
    Like golf clubs. Every year or two they come out with better clubs.
  • rpf65
    rpf65 Posts: 2,127
    http://www.accessories4less.com/make-a-store/item/marsr5010/marantz-sr5010-7.2-ch-x-100-watts-networking-a/v-receiver/1.html
    Figure you have a basic 5.1 or 7.1 system, and just want a newer model AVR. This has the newest decoding formats, and will allow 4K streaming.
    So long as you don't have power hungry speakers, guessing bookies, this should work for you.
    tonyb Posts: 33,069
    You really don't need a receiver to stream 4k, most all the newer 4k TV's do that on their own. Their is a lot of redundancy in gear. TV'S, receivers, bdp's, Firesticks, Roku....they all stream from the same sources. I don't see why one would need multiple pieces that stream. Especially with 4k material as it's only available by a few sources. Each brand also has their own 4k movie box they want you to cough up an extra 3-4-5 hundies for.....which is a waste imho.
  • rpf65
    rpf65 Posts: 2,127
    I agree that there is a lot of redundancy out there. It is by far easier for a novice to ask if an AVR will stream/decode 4K content than to remember all the letters/numbers to decode that content.
    Friend of mine, who knows close to nothing about HT just bought a new tv. Followed my advice, and made sure he could stream 4K, even though he has no subscriptions to those services. He also payed to have it calibrated, which I told him didn't happen.
    The OP said he has had his tv for 16 years, so I'm guessing HT isn't really a high priority to him. Just easier for people to understand that if you can stream 4K, it will decode the content if/when it becomes a viable format.
    Just suggesting an easier way to hopefully get an extra month or two before the next latest and greatest thing comes out.
    tonyb Posts: 33,069
    I hear ya, just that today and down the road compatibility issues are going to be huge. Manufacturers aren't exactly forthcoming either. It's easier for some to just say you need a 4k receiver, bdp, and 4k HDMI cables to access 4k material. You sell more products that way.
    It's important, in my view anyway, for anyone to be a bit more specific on what they want their system/gear to do and what accompanying gear they plan to use with it. That way we can see where the issues will arise, where they need to spend the money and where they don't.
    Certainly is confusing for the average joe who isn't that into this stuff and that makes them the perfect target for a salesman.
