Can I use both of the balanced and unbalanced inputs from and Emotiva XPA-L1?
afterburnt
Like having the unbalanced hooked up to an AVR and the balanced hooked up to an Oppo?
is one ear lower than the other?
Yes, but you can't use both at the same time. There is a switch on the back of the amp that switches between balanced and unbalanced inputs. How do you like the two mono amps?
I like them a lot. I want to try them without the AVR.
