MONITOR 7-B BASS RESPONSE IN NEW REPLACEMENT WOOFER
Need some guidance. I have had a pair of early release Monitor 7-b'S since 1985. One of the woofers blew and was replaced. The issue is that since I have upgraded my receiver to an HK 3490, the very low bass response is much greater in the replaced woofer. Part numbers are original woofer MW-6500—replacement MW-6200. The question is should I replace the MW-6500 and will this resolve the bass response issue?
  • deucekazoo
    deucekazoo Posts: 146
    You need to find another MW-6500 and replace the 6200. Keep it original because the x-over was designed for that woofer. I think if you call POLK they still have these or you can try EBay.
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
    Working on getting SDAs
  • deucekazoo
    Also the replacement driver for the MW-6500 is MW-6503. It needs to be 8 ohm.
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
    F1nut Posts: 52,101
    deucekazoo wrote: »
    ^ THIS ^
