NAD 925 to power SDA2bs any thoughts any comments.
I have a chance to get nice NAD 925 THX amp and wonder if it would be a good buy for powering my 2bs it is rated at 120 w per channel but is a 5 channel amp and can be bridged. One thing I don't know is if it is common ground, Thanks for your help.
Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub
  • JPete
    JPete Posts: 298
    I can't answer the common ground question, but 120 wpc should be fine unless you want to blow out the windows. Are you just looking for something different? Many good deals popping up on all of the auction and sales sites for 2 channel amps though. You using these in an HT setup?
    Lexicon RT-10, Parasound P5, McCormack DNA 0.5, Polk SDA CRS+, SVS Sub
    Schiit Modi, Luminous Audio Axiom II, McCormack DNA-1, Digital Phase AP 2
    Marantz AV7701, Emotiva XPA-5, Paradigm 11se Mkii, DCM Time Windows, NHT 2C, SVS Sub
    Spares - Kenwood C1 Pre, NAD 2200PE, Polk Monitor 10B, Polk Model 11, other odds and ends
  • honestaquarian
    honestaquarian Posts: 3,259
    You could always contact NAD and ask. Most of the time when someone encounters non common grounded amplifiers,they are mono block, dual mono,multichannel and some esoteric designs.
  • I would like to add an amp to my avr that can take some of the load off as my 2bs need a little more power after the mods. This NAD 925 is only 250 bucks, seems like a good price and local as well.
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
