Does anyone know if the TSx 550Ts have active or passive crossovers?
I'd like to bi-wire / bi-amp these speakers and if they have passive crossovers, it would be a waste of time.
Best Answers
  • honestaquarian
    honestaquarian Posts: 3,259
    Answer ✓
    An active crossover is an electronic crossover,which is usually an outboard unit that is inserted into the signal path. A passive crossover is what you find in most loudspeakers.
  • Beachcomber
    Beachcomber Posts: 6
    Answer ✓
    Unfortunately, the passive crossovers only use impedance or resistance to control signal resulting in extra heat and loss of signal. I was thinking of bi wiring the TSx 550s, but with the passive crossovers, this would be a waste of energy and resources.
    Thanks for your guidance.
  • nguyendot
    nguyendot Posts: 3,594
    Answer ✓
    In general, 99% of home speakers are passive crossovers. If they're active you'll usually have an external box prior to amplification.
    Main Surround -
  • Beachcomber
    Answer ✓
    Thanks for the guidance
Answers
  • nguyendot
    Main Surround -
