Dynamatting Oppo Help
Nightfall
Nightfall Posts: 10,083
edited March 2016 in Electronics
Where can I put Dynamat? Can I cover the entire top of the transport leaving a circular hole where there is a circular metal plate screwed down? There are zero vent slots in the top cover, I can completely line that? Should I remove the PCB's and Dynamat underneath them or just the visible areas?
afterburnt wrote: »
Village Idiot of Club Polk
  • Nightfall
    My worry about Dynamatting under the PCB's is the bottom of the PCB and/or solder joints coming in contact with the Dynamat and making magic smoke.
    afterburnt wrote: »
    F1nut Posts: 52,149
    A little goes a long way. Cover the raised rectangle, put some on the circle leaving the screws exposed and on any open bare areas on the chassis bottom and walls. Do not put any under the boards. Also, line the underside of the lid.
  • Nightfall
    I stayed well away from the edges of the lid just out of fear of it getting in the way of putting the lid back on properly.
    afterburnt wrote: »
  • Nightfall
    afterburnt wrote: »
  • hochpt21
    hochpt21 Posts: 5,423
    Nicely done.
    Let us know if you hear improvement.
  • Nightfall
    Okay I'm calling it good enough. I purposely stayed away from the two white plastic pieces that are wrapped in wire in the last picture. Wasn't sure if the Dynamat would interfere with those or not.
    afterburnt wrote: »
    F1nut Posts: 52,149
    edited March 2016
    That should be fine. When you flick your fingernail on any of those surfaces now it sound dead, no ringing.
    Just one thing, check that the strips on the side walls of the lid are not going to come in contact with the chassis side walls as the black tar will stick.
  • Nightfall
    Nope. The screw threads in the lid are raised and keep the lid from closing down enough for the Dynamat to touch the chassis.
    afterburnt wrote: »
    F1nut Posts: 52,149
    Ok good, just wanted you to check that.
  • Nightfall
    edited March 2016
    I appreciate it, thank you.
    It feels way more solid now, as if the lid is thick metal instead of thin riiiiiiiiiiiing. The tray now closes with a "thunk" instead of a "tink".
    I hope my ridiculous choice of words makes sense. It's hard to put noises and sounds into words on a screen.
    I'd do my AVR too but I don't really care. It's not involved in playing back CD's or LP's and it would be much more difficult to do anyway. The lid has a lot of ventilation holes and it would just be a pain to get any Dynamat anywhere inside it.
    afterburnt wrote: »
    F1nut Posts: 52,149
    Your descriptions are spot on.
    Toolfan66 Posts: 18,287
    I have been wanting to do my OPPO's for some time now..
  • Nightfall
    Toolfan66 wrote: »
    No time like the present. Put on some music and grab a screw driver, tape measure, sharpie, and scissors.
    afterburnt wrote: »
  • Nightfall
    nbrowser wrote: »
    On a serious side, I've got some sound deadening material left over from my SDA job to do my 93, might just copy what you've done as it looks pretty good.
    Do it to it. Don't skip the Marantz. You listen to redbook CD's on the Marantz and everything else on the Oppo or do you not have SACD's and only use the Oppo for movies?
    afterburnt wrote: »
  • Nightfall
    edited March 2016
    If you listen to CD's and iPod through the Marantz and don't have SACD's what do you play in the Oppo?
    I don't have any SACD's yet either. I really want Pink Floyd in SACD. I check my record store every time but they never have any of them, I'll just have to get it online I guess.
    afterburnt wrote: »
  • Nightfall
    Okay, that makes more sense and was what I figured.
    afterburnt wrote: »
  • Nightfall
    edited March 2016
    I am very curious as to how SACD (DSD) sounds vs 192/24 FLAC from HDTracks.
    afterburnt wrote: »
    txcoastal1 Posts: 13,519
    nbrowser wrote: »
    Nightfall wrote: »
    Many apologies, and I'm on the serious hunt for a copy of Dire Straights Brothers In Arms SACD to feed into the Oppo. Such a nice sounded CD...I can only imagine how good the SACD would sound.
    Ken I think I'm doubled up on the SACD, I'll check in the morning...if so I will send it to you
  • mikeyb128
    mikeyb128 Posts: 2,885
    nbrowser wrote: »
    txcoastal1 wrote: »
    nbrowser wrote: »
    Nightfall wrote: »
    Thank you for the kind offer! I'll gladly pay for it too.
    If the second copy fall through, I see one on Amazon for 7.99, and I have Amazon prime. Let me know I could help you out on that one too.
    Oppo looks great. Might have to fondle the insides of my 105, Get rid of those tings.
    2 channel:
    Theater:
  • mikeyb128
    Hahaha there is an Amazon.ca so that's like 40 cents In American monies lol
    2 channel:
    Theater:
    nbrowser wrote: »
    txcoastal1 wrote: »
    nbrowser wrote: »
    Nightfall wrote: »
    Is this the one you are looking for
    http://www.mofi.com/product_p/udsacd2099.htm
    nbrowser wrote: »
    txcoastal1 wrote: »
    Something like that...I figure I've got the ability to play SACDs now...got to get at least one SACD to try that out with...
    I found one copy of it looking for the other. Brothers in Arms is good but I think Shangri La is a better SACD.
    To me the ones to have and try are according to my taste
    DSOTM, Santana Abraxas are great
    Will have more time to look this weekend
    So did you find dynamating the OPPO helped??
