Boxes
rothe
rothe Posts: 1
I have two Polk Momo 10 inch subs in the truck of my car. It is a convertable and I have an MTX amp giving it like 800 watts each. The question I have is, the boxes I am using with the subs are a bit bigger than the specs require for air space. How much of a difference will that make? It is only like .02 or so cubic feet.
Post edited by rothe on
    VR3 Posts: 29,700
    edited March 2004
    Go to main page, scroll down - Car Audio forum! You will get much better help there, welcome to club polk and good luck!
  • pjdami
    pjdami Posts: 1,894
    edited March 2004
    if it's only 0.02 cubic feet in difference for the sub box then not a problem. One would have a hard time cutting wood within that spec. 0.02 is just a little bit bigger than 1/8 X 1/8 X 1 foot volume wood strip.
