Polk RT 10 and Matching Center Help
mrhaboobi
Heya
I have a set of Polk RT10's as my fronts, and also RT10's as my rear ( though i also have set of RT8's as an option ). Wanted to know what the best matching center would be. I used to have a CS250.. i want to try and get a similar look, what options would people suggest that timbre match the fronts? ive heard of cs245 cs275 cs300 and cs400. The look starts to change alot across the models.. is there anything similar looking to the 250 which would match my speakers well?
Also im looking for a replacement foot for an RT8 as mine has been damaged..
CS350LS
Yeah but she's as big as a boat. Need something a bit less wide
Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
Power Amp: Sunfire Architect's Choice Series II
Preamp: Adcom GFP-750
SACD/CD: Oppo BDP-95
Tuner: Sansui TU-717
TT: Technics SL-MA1
Phono Pre: Emotiva XPS-1
Music Server: Mac Mini w/JRiver - iPad w/JRemote
DAC: Eastern Electric MiniMax Plus
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
