Polk LSI 15 for sale for $350 worth the upgrade?
Hello I have a chance to purchase a pair of LSI 15's for $350. I currently have the Rti10s and use my system about 50/50 for music/ht. Would this be a worthy the upgrade? They would be powered by an XPA-5 and I have an SVS 12 plus subwoofer.
I like the Rti10 but they give me listener fatigue and when listening to music. It seems that the Lsi's would do better in that department from what I've read here. They are about a two hour drive from home but for $350 it seems it would be worth the drive.
Any thoughts?
Thanks.
  • Legender
    Legender Posts: 478
    I have some LSI 15s that I use for Music only in a 2 channel set up. I upgraded from RTi12s. I can tell you that in my system they are very easy to listen to and have done so for hours. I'm using a Marantz preamp and an older model Kenwood Basic M2A that drives those 4Ω speakers to about 300 watts.
    I paid $350 for mine and the grills need some attention but they sound awesome and they don't have any upgrades yet, but I have purchased the new woofers for them. But enjoy them as they are just the same.
    I use the RTI 12s for the home theater room and they do fine and only occasionally use them for 7 channel stereo.
    If you want to solve your listener fatigue I do believe these would help as they are known to be more 'musical' than the RT line. Not sure how the EMO would drive them. That will be what you'd need to check out. At that price you could purchase them and try them out and then re-sell them if they didn't work for you. Just a thought.
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
    The listening fatigue is because the Emo amp is a bit bright on the top end, as well as the speakers. The LSI's are a more laid back speaker and less bright on the top end so it may be better for music. Movies though, it may not be as dynamic as your RTI10'S.
    You could go that route, for the 350 bucks you could easily re sell them if they don't float your boat. You can also swap out the amp for a warmer sounding one, for about the same price. Cables will also play a role so a warmer sounding speaker cable/rca interconnects would help alleviate that fatigue you get.
  • K_M
    K_M Posts: 1,631
    The Lsi have a very smooth, nicely refined sound, that is airy and clear, but never forward or tiring.
    I love the Lsi for movies and music.
    They may come across as a bit recessed or laid back to some, and I am sure amplification and acoustics will change that characteristic some also.
    F1nut Posts: 52,406
    tonyb wrote: »
    This
  • mikeyb128
    mikeyb128 Posts: 2,885
    For 350 I would be all over that.
    2 channel:
    Theater:
  • albertnsb
    I going to give them a go it seems like a no brainer. I will let you guys know what i think once a get a couple days with them.
    You guys are awesome thanks for the advice.
  • Legender
    Legender Posts: 478
    Great choice.. best part is you're going along for the journey. We all are striving for the best possible sound we're willing to pay for. Our journey is a learning process and your/our experiences serve to educate us and help others along the way. Yes, let us know what you think.
  • Polkie2009
    Polkie2009 Posts: 3,834
    Any pics available of the LSi15's you're getting? What finish are they?
  • eclypse
    eclypse Posts: 595
    :) if I ever find a pair of lsi15's in my area I would be letting you know after I picked them up!
    I believe there's a woofer upgrade for thrm that's known using a polk audio car sub to increase the bass.
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
  • skrol
    skrol Posts: 3,499
    Some things to note are that they love a good high current amp to control them and they need room to breath (away from walls). But for that price, go for it. If you don't like them, you should be able to flip them for more.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • K_M
    K_M Posts: 1,631
    eclypse wrote: »
    I believe there's a woofer upgrade for them that's known using a polk audio car sub to increase the bass.
    It is a Polk car sub correct, but it does not increase the bass at all, but reduces the boomy mid/upper bass a decent bit.
  • Legender
    Legender Posts: 478
    This is the one you should use on the swap:
    Posted from another poster... not mine:
    The DB840s do sound tighter than the stock, which tended to be a bit boomy. Never regretted the swap...
